11-07-2016, 13:03 | #1 (permalink) |
Insane Poster Join Date: Oct 2009 Location: TURKEY Age: 42
Member: 1135902 Status: Offline Sonork: 1636815 Thanks Meter: 5 | mtk 6572 will kill phone Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A3B4053173 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x00 , OEM : 0000 [eMMC] : FLASH_INF : [NOT_IN_BASE] , [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_BRT : 0x00000000 , 0x00000000 , 0x00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 [eMMC] : FLASH_UCP : 0 MiB [eMMC BAD_CONN] DEV RID : 0x4642A449E11B8F59842BC2165E2733A8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : DA_HANDSET_ROM_INFO_NOT_FOUND SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : ztenj72_we_f01_jb3 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! please write to flash help me |
11-07-2016, 13:04 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: [eMMC] : FLASH_VEN : 0x00 , OEM : 0000 [eMMC] : FLASH_INF : [NOT_IN_BASE] , [eMMC] : FLASH_CID : 00000000000000000000000000000000 [eMMC] : FLASH_BRT : 0x00000000 , 0x00000000 , 0x00000000 [eMMC] : FLASH_LEN : 0x0000000000000000 [eMMC] : FLASH_UCP : 0 MiB [eMMC BAD_CONN] |
11-07-2016, 13:08 | #3 (permalink) |
Member: 1135902 Status: Offline Sonork: 1636815 Thanks Meter: 5 | Different mistakes every time ScatCFG : BaseBand : MT6572 , Project : ztenj72_we_f01_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3911 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase Error! Something went wrong! |
11-07-2016, 13:09 | #4 (permalink) | |
Member: 1135902 Status: Offline Sonork: 1636815 Thanks Meter: 5 | Quote:
