03-01-2021, 05:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India
Member: 173081 Status: Offline Thanks Meter: 352 | Mtk auth bypass function required in next update VIVO Y81 READ FIRMAWARE, WRITE READED & ORIGINAL FIRMWARE SUCCESS LOGS BELOW :- Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 6D72283CE8B47B352D2A46C9ED539D5B BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 26D028C7B85D829003A07A8B4CCA44A65B85F10CBD7D3D72C2 A6703E6A40F28B AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E03445A25106551 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 624ABF4EA0DA8F3D47E17FEB54F2D9D3 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-08-01 Build Time : 18.08.2020 Product Model : vivo 1808 Product Brand : vivo Product Name : PD1732F_EX Product Device : PD1732F_EX Product Manfct : vivo Product Info : k62v1_64_bsp Product Model : PD1732F_EX Product Board : k62v1_64_bsp Board Platform : mt6765 MT6765__vivo__PD1732F_EX__8.1.0__O11019__k62v1_64_ bsp Read : preloader.bin Read : recovery.img Read : backup.img Read : survival.img Read : cust.img ExtSparse : Compression ratio : 55% Read : persist.img ExtSparse : Compression ratio : 99% Read : efuse.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : odmdtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 50% Read : system.img ExtSparse : Compression ratio : 10% Read : cache.img Read : userdata.img FW Size : 4.30 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : E:\DOWNLOAD\MT6765__vivo__PD1732F_EX__8.1.0__O1101 9__k62v1_64_bsp\ Done! Elapsed: 00:21:12 Operation : Write Flash [ v2.21 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :23 [FL] : Set : preloader_k62v1_64_bsp.bin [FL] : Set : recovery-verified.img [FL] : Set : survival-verified.img [FL] : Set : oem.img [FL] : Set : efuse.img [FL] : Set : md1img-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : sspm-verified.img [FL] : Set : lk-verified.img [FL] : Set : lk-verified.img [FL] : Set : boot-verified.img [FL] : Set : logo-verified.bin [FL] : Set : odmdtbo-verified.img [FL] : Set : tee-verified.img [FL] : Set : tee-verified.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x1739F5DEC [ 5.81 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 6D72283CE8B47B352D2A46C9ED539D5B BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 26D028C7B85D829003A07A8B4CCA44A65B85F10CBD7D3D72C2 A6703E6A40F28B AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E03445A25106551 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 624ABF4EA0DA8F3D47E17FEB54F2D9D3 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000005688000 Erase : 0x0000000007688000 : 0x0000000004000000 Erase : 0x000000000C088000 : 0x0000000014000000 Erase : 0x0000000021800000 : 0x0000000000800000 Erase : 0x0000000025000000 : 0x0000000000200000 Erase : 0x0000000025500000 : 0x0000000009980000 Erase : 0x0000000032E80000 : 0x0000000257180000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : SURVIVAL Write : CUST FAIL : SEC : IMG TYPE MISMATCH Write : EFUSE Write : MD1IMG Write : MD1DSP Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : ODMDTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:47 Reconnect Power/Cable! Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-08-01 Build Time : 18.08.2020 Product Model : vivo 1808 Product Brand : vivo Product Name : PD1732F_EX Product Device : PD1732F_EX Product Manfct : vivo Product Info : k62v1_64_bsp Product Model : PD1732F_EX Product Board : k62v1_64_bsp Board Platform : mt6765 Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] Operation : Write Flash [ v2.21 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :23 [FL] : Set : preloader_k62v1_64_bsp.bin [FL] : Set : recovery.img [FL] : Set : survival.img [FL] : Set : cust.img [FL] : Set : efuse.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x10F25A298 [ 4.24 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 6D72283CE8B47B352D2A46C9ED539D5B BROM : SecLevel : 0x000000E0 BROM : SecMode : EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 26D028C7B85D829003A07A8B4CCA44A65B85F10CBD7D3D72C2 A6703E6A40F28B AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E03445A25106551 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 624ABF4EA0DA8F3D47E17FEB54F2D9D3 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000005688000 Erase : 0x0000000007688000 : 0x0000000004000000 Erase : 0x000000000C088000 : 0x0000000004000000 Erase : 0x0000000010A88000 : 0x000000000F600000 Erase : 0x0000000021800000 : 0x0000000000800000 Erase : 0x0000000025000000 : 0x0000000000200000 Erase : 0x0000000025500000 : 0x0000000009980000 Erase : 0x0000000032E80000 : 0x0000000217180000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : SURVIVAL Write : CUST FAIL : SEC : IMG TYPE MISMATCH Write : EFUSE Write : MD1IMG Write : MD1DSP Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : ODMDTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:48 Reconnect Power/Cable! REGARDS AJAY GUPTA |
03-01-2021, 05:28 | #2 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,639 | Hello infinity-box was the first Tool providing Auth bypass and others, see sSLA option |
The Following 3 Users Say Thank You to yuranc8 For This Useful Post: |
03-01-2021, 05:47 | #3 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | the best thing in CM2 is boot helper program which auto learned settings according to CPU you don't need to select model number |
The Following User Says Thank You to khanzada606 For This Useful Post: |
03-01-2021, 15:09 | #4 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | Quote:
And try to use sSLA checkbox | |
03-02-2021, 10:41 | #5 (permalink) | |
Member: 173081 Status: Offline Thanks Meter: 352 | Quote:
