08-26-2016, 13:13 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: India
Member: 1001635 Status: Offline Thanks Meter: 63 | Mtk based android sets' Hang On Logo Problem. Now a days I am getting many mtk based android sets in hang on logo problem.I flash those sets with correct firmwares as mentioned in back sticker as well as other working firmwares also. But after successful flashing the sets remain in the same hang on logo condition. I sets successfully pass emmc test also. I also full erase the phones and then flash but not get any success. After successful flash I wipe the sets and then it come into recovery mode.I do this because somewhere in this forum I saw a post of you where you said that if the set come into recovery mode then there is a chance to recover it. Please tell me that what should I do with this sets now........ |
08-26-2016, 13:56 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello, First of all post all the operations u have done. Also make HW Test, and post report. |
The Following User Says Thank You to chandanps18 For This Useful Post: |
08-26-2016, 16:06 | #3 (permalink) | |
Member: 1001635 Status: Offline Thanks Meter: 63 | Quote:
H/W VER :V1.1 S/W VER:V08 READ INFO LOG Operation : Check / Read Info [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A2085042AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A2085042AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x76C005822BF648F2E14D3247DFEEFB6A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : D321 ProdModel : Micromax D321 Device : D321 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n EXTRA : LCD [0] : ili9806e_fwvga_dsi_vdo_txd LCD [1] : hx8379c_fwvga_dsi_vdo_tcl LCD [2] : ili9806e_fwvga_dsi_vdo_dj LCD [3] : ili9806e_fwvga_dsi_vdo_glass LCD [4] : ili9806e_fwvga_dsi_vdo_djn LCD Res : 854x480 TOUCH [0] : GT9XX CAM [0] : ov5645_mipi_yuv CAM [1] : ov5646_mipi_yuv CAM [2] : sp0a19_yuv CAM [3] : gc0329_yuv CAM [4] : hi258_mipi_yuv MODEM : mt6572_s5201bp_hspa_gemini_20141128 LOCALE : en_US en_GB hi_IN de_DE fr_FR es_ES in_ID it_IT ms_MY pt_BR vi_VN tr_TR ar_EG zh_CN ru_RU hdpi -sw600dp -sw720dp Done! Elapsed: 00:00:30 Reconnect Power/Cable! fLASE ERASE LOG Operation : Flash Erase [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A2085042AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A2085042AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x76C005822BF648F2E14D3247DFEEFB6A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Erase Flash now ... Keep Preloader alive Flash erase done Done! Elapsed: 00:00:22 Reconnect Power/Cable! FLASHING LOG ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A2085042AD Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A2085042AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x76C005822BF648F2E14D3247DFEEFB6A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x000000009DE40000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:28 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:21 Reconnect Power/Cable! HW TEST LOG Operation : HW Test [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A2085042AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A2085042AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x76C005822BF648F2E14D3247DFEEFB6A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery ) [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A4834473164040501A2085042AD [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:39 Reconnect Power/Cable! PLEASE HELP............... | |
