06-08-2016, 10:18 | #3 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2095478 Status: Offline Thanks Meter: 49 | ok here is logo: Card found: S/N : 6AEB6F7F , v0130 Chinese Miracle II [SPD module] v 1.16 Start at : [07-Jun-16 / 2:44:28 PM] Operation : Format File System / Reset Settings [ v1.16 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:458 3è~~ Boot Ok |
06-08-2016, 11:43 | #5 (permalink) |
Member: 2095478 Status: Offline Thanks Meter: 49 | The phone's condition is : when you on it, it will keep restarting. I checked the phone's hardware No problem ,the same model of the phone came to my Shop 2-3 times daily with the same Problem, the Model is M-HORSE 930. Card found: S/N : 6AEB6F7F , v0130 Chinese Miracle II [SPD module] v 1.18 Start at : [08/06/2016 / 12:08:15] Operation : Format File System / Reset Settings [ v1.18 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:458 3è~~ Boot Ok |
06-08-2016, 17:46 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | This problem was reported sometime back but seems Lack of samples at hand,Lets wait for SPD UPDATE HOPE TEAM WILL SOLVE IT MAYBE. |
06-09-2016, 12:25 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | For 3 years no one send any phone When I find something - will add. Otherwise - not. If I not see problem - then it not exists. All is simple |
