05-13-2022, 09:11 | #1 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | [MTK sec 2022] models that can not boot 1. For Infinix and Tecno use Infinix/Tecno without Test Point methos 2. For Vivo use Vivo without Test Point methos 3. Try different loaders and base | model | DA | Local SLA options (see images below) 4. if you see in software log text TYPE: NEXTGEN [LUCI] select LUCI DA from the list. NOTE: latest CM2MT2 version is required to work with latest DA files! 5. If problem still exist - use TEST-POINT More step: 1. Install laters CM2MT2 version and click to [Identify] - you will see list of suggested loaders. Try it. 2. Remember about boot keys, f.e. Volume + and Volume - buttons 3. In some cases it may be HW fault, f.e. faulty device DRAM or EMMC. Make HW report and try also boot over FireFly mode. 4. If nothing helps it may be some kind of new unsupported device - copy/paste here software log text and info about about the phone, developers will check it 5. Use this tool and upload your tested test-point images or new DA to server. How to select different loaders: Try to change these config values: Last edited by InfinityHelp; 11-05-2023 at 15:14. |
The Following 18 Users Say Thank You to InfinityHelp For This Useful Post: |
05-13-2022, 09:20 | #2 (permalink) |
Junior Member Join Date: Dec 2007
Member: 644926 Status: Offline Thanks Meter: 2 | PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM21) MODE : PRELOADER PORT PORT : 21 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6833 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Palmer TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6833 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Last edited by Navanil_ambuj; 05-13-2022 at 09:20. Reason: vivio v 23 e |
05-13-2022, 12:08 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
05-13-2022, 12:13 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | vivo y33s v2109 Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
05-13-2022, 15:01 | #8 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Nigeria Rivers State
Member: 2332337 Status: Offline Thanks Meter: 35 | Gionee M7L Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM17) MODE : BOOTROM PORT : 17 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6758 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Vinson TYPE : MODERN [RAPHAEL] BROM : MEID : C593E3BB1BFE76227FFE908BF929F442 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : F95AC8C3A2F3FD5A8A687312E6CAC07FD6A1E08176C825EDDA 825269016736B3 BROM : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6758 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Oblinks1 For This Useful Post: |
05-18-2022, 05:51 | #9 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Pakistan. Rahim Yar Khan
Member: 1977629 Status: Offline Thanks Meter: 429 | plz add nokia ta-1235 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM49) MODE : NOKIA USB SERIAL PORT : 49 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9D2706EB9212F4E0D80CAB98B9BC64EF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : GEMINIVAL.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : GEMINIVAL.10.01.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 353102xxxxxxxxxx IMEI[2] : 353102xxxxxxxxxx NCK : 20 digits PROV : 24407000 Saved as : 353102xxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:31 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM49) MODE : NOKIA USB SERIAL PORT : 49 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9D2706EB9212F4E0D80CAB98B9BC64EF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : GEMINIVAL.10.01.11.p1 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : Device AutoID failed! Error : Fail to init protocol! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to dany_boy For This Useful Post: |
05-18-2022, 07:57 | #10 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
The Following User Says Thank You to kamal_singla For This Useful Post: |
05-19-2022, 18:46 | #12 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | info Code: Waiting for mtk usb device... ok BootMode : Preloader[COM7] DriverName : MediaTek PreLoader USB VCOM (Android) DriverPath : usb\vid_0e8d&pid_2000\5&15499710&0&1 DriverID : wdm_usb DriverVersion : 3.0.1504.0 DriverDate : 1-22-2015 InfPath : oem24.inf ProviderName : MediaTek Inc. ● BBChip ID MT6768 ● BBChip Inf 707:8A00:CA00:0 ● Chip PID Helio P65 ● Chip UID Talbot ● Chip Ver CHIP_VER_E1 BRom::SEC:{0x5}[SBC:ON:SLA:OFF:DAA:ON] BRom stage Re-configuration ● BR_MEID:0x9EC61FCC978470AD54E26EF2A20FDF2B Sending Download Agent... Successfully received DA sync cahr Start setup da environment... Successfully received 2nd DA sync signal Boot and enter 1nd DA... Boot 1nd Da done! Getting Ram Info ● Sram 448.00KB ● Dram 4.00GB Boot and enter 2nd DA... Boot 2nd Da done! Getting HW Info ● Storage eMMC ● BOOT1 4.00MB ● BOOT2 4.00MB ● RPMB 16.00MB ● GP1 00000000 ● GP2 00000000 ● GP3 00000000 ● GP4 00000000 ● USR 116.48GB ● MLC 00000000 ● SLC 00000001 ● EOL 00000001 ● LCYCLE 00000000 ● CID 90014A68444561503303009E29177835 ● MFRID 0x90 ● Vendor SkHynix ● Card BGA BGA (Discrete embedded) ● OEMID 0x4a ● Product hDEaP3 ● Revision 0.3 ● Card SN 0x009e2917 ● MFDate 7/2021 ● EMCP Unknown ● Capacity 0x1d20800000:116.51GB ● RNID ED72133BAE7829CED88A6E56390A582B Switching to usb high-speed... ===== wait for DA high speed port ===== Waiting for mtk usb device... ok BootMode : MTK DA VCOM[COM6] DriverName : MediaTek DA USB VCOM (Android) DriverPath : usb\vid_0e8d&pid_2001\5&15499710&0&1 DriverID : wdm_usb DriverVersion : 3.0.1504.0 DriverDate : 1-22-2015 InfPath : oem24.inf ProviderName : MediaTek Inc. ● USBSpeed high-speed Gathering partitions info... ===== wait for DA S/W detection report ===== ● ManfcID VIVO ● MName 2037 ● Model V2037 ● Product VIVO ● Fw Ver SP1A.210812.003 RELEASE-KEYS ● BuildID SP1A.210812.003 ● Android 12 (Snow Cone) ● EMI ID PRELOADER_K69V1_64 ● S Patch 2022-04-01 ● Region EN-US ● CPUApi ARM64-V8A,ARMEABI-V7A,ARMEABI ● MTK Ver ALPS-MP-S0.MSSI1.TC19SP2 ● SVer COMPILER04081609 ● Host COMSZ01110051 ● Screen TFT ● SYSVer PD2066F_EX_A_6.14.1 ● HWVer PD2066F_EXMA ● BT Addr E4:F1:D4:E4:1F:D6 ● Mac Addr E4:F1:D4:E4:1F:D7 Rebooting device... Done Code: Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing BootROM BROM : Enforcing Failed! Skip! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT Error : Fail to init protocol! >>> BROM connection mode required! Reconnect Power/Cable! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-20-2022, 14:23 | #13 (permalink) | |
currently solution is to find TP and do work | |
05-20-2022, 14:46 | #14 (permalink) | |
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
i'm just want to say please add this new sec . Thanks | |
05-25-2022, 13:28 | #15 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | vivo pd 2150f security update 14 april 2022 Quote:
The Following User Says Thank You to solusi hp For This Useful Post: |
