Old 01-04-2009, 13:55   #1 (permalink)
Member: 337837
Thanks Meter: 538
Strange problem with infinity + pinfinder
AFTER SUCCESSFULLY FIND PINS VIA PIN-FINDER I TRIED TO FORMAT IT WITH CHINESE MIRACLE 2.73 IT SHOWS THE FOLLOWING ERROR.I TRY IT ON 4-5 PIECES BUT SAME PROBLEM
COM21 [VCP0] selected
module v2.73
Action: reset settings
Model: Autodetect 6228, 6229, 6230 NAND
Checking data, wait...
19200 autodetect
Initializing [6205:8B00]...
CPU: MT6205
high speed boot On
Connecting, wait...
warning: wrong packet cs
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 101 sec
Remove/Install battery now !
PLEASE INFINITY SUPPORT SOLVE THIS PROBLEM AS SOON AS POSSIBLE
Old 01-04-2009, 14:02   #2 (permalink)
irish_4's Avatar
Member: 79870
Thanks Meter: 52
try to format using complete mode and adjust your baudrate speed to lower
Old 01-04-2009, 14:04   #3 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,039
baudrate speed 115200
Old 01-04-2009, 14:17   #4 (permalink)
Member: 337837
Thanks Meter: 538
complete mode + speed 11500
phone finalized test mode but still same error
Old 01-04-2009, 16:15   #5 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
hi Sairat..
I had almost the same problem as u had while formating Sigmatel T33..
I tried alot but kept getting the same error..
What i did was i opend up the fone n soldered wires or rx tx gnd as marked on the board. It hardly took me around 25 sec to format fone.
Try it if it works coz it worked for me bro. I do hope u have infinity rx tx gnd custom made cable
Br,
TOm
Old 01-05-2009, 06:51   #6 (permalink)
Member: 337837
Thanks Meter: 538
Originally Posted by tom313rd View Post
hi sairat..
I had almost the same problem as u had while formating sigmatel t33..
br,
tom
thanks mate for your kind help but what about pin-finder i think we put it in a bin if it don't work for us properly
Old 01-05-2009, 22:06   #7 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
module v2.73
19200 autodetect
CPU: MT6205
high speed boot On
Connecting, wait...
Dearestest Friend,
before ask somebody to "solve the problem" please, think what is the problem exactly !
Please, look at your posted log carefully and tell me what is the problem exactly !
Old 01-06-2009, 17:04   #8 (permalink)
Member: 161115
Thanks Meter: 3,039
@InfinityN
Yes bro ..You are 100 % right ...
Old 01-09-2009, 10:29   #9 (permalink)
Member: 267256
Thanks Meter: 72
me to i have this probleme in 3 phones ! PLEASE INFINITY SUPPORT SOLVE THIS PROBLEM AS SOON AS POSSIBLE
The Following User Says Thank You to wajdi50001 For This Useful Post:
Old 01-10-2009, 05:53   #10 (permalink)
Member: 565230
Thanks Meter: 22
module v2.73
19200 autodetect
CPU: MT6205
high speed boot On
Connecting, wait...
you have did 2 fault
1-the pinout are detected is for second cpu ( mt6205 )
2-you select the wrong packet cs ( 6228, 6229, 6230 NAND )
Old 01-10-2009, 18:29   #11 (permalink)
Member: 130995
Thanks Meter: 35,227
You must read http://forum.gsmhosting.com/vbb/show...89&postcount=7
sfr 111 succefull unloked with infinity+pinfinder noure30 Infinity-Box 5 02-17-2010 12:04
I have a problem with Infinity pinfinder on pinout magucha Infinity-Box 1 12-27-2009 21:02
A strange problem with PinFinder box... debeliamark Infinity-Box 2 02-25-2009 19:08
succesfully unlock alcatel s210 with infinity+pinfinder Haouas Infinity-Box 1 07-26-2008 20:33
strange problem with infinity momayaz Infinity-Box 6 08-02-2007 08:42
Page generated in 0.24390 seconds with 9 queries
