11-29-2014, 16:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | MTK6582 unsupported Start at : [11/29/2014 / 7:29:54 AM] Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E4361726420109C136033B0AF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Info read not done Erased phone or unsupported FlashIc? |
11-29-2014, 17:24 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Just t2 steps make it supported : 1. Charge battery Fully 2. Not press any key, when connect. |
The Following User Says Thank You to Dzirt For This Useful Post: |
11-30-2014, 13:01 | #3 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | pattern lock how to remove how to read ? how to make backup flash ? Card found: S/N 2682:0128 Chinese Miracle II [MTK module] v 1.06 Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E4361726420109C136033B0AF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E4361726420109C136033B0AF [eMMC] : FLASH_LEN : 0x00000001CE100000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... #819 : Data CRC Error : 8200 , 8000 Read error Operation Failed Elapsed: 00:00:57 Reconnect Power/Cable! Operation : Read PatternLock [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Operation : Read PatternLock [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E4361726420109C136033B0AF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E4361726420109C136033B0AF [eMMC] : FLASH_LEN : 0x00000001CE100000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1023 MiB Magic Ok Mount point : /data PatternLock not set Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
11-30-2014, 13:15 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Seems as phone have still empty battery or something else ( like cable problem / connection problem ). Patternlock - seems as not set. If phone asks for google account - it not help. |
12-01-2014, 07:33 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | As I told - it have not patter. Password reading is exist, but you need have 2-3 ATI latest video cards to brute it. Probably - we add it later. Resetting feature for password is on way, but still need time to finish it. IF you have week or so - you can wait for update/test exe, if not - only format FFS to reset all. |
12-01-2014, 07:34 | #7 (permalink) |
