11-26-2010, 20:22 | #2 (permalink) | |
Please, read full flash from this phone (like 208 model) and send full flash backup file (or link) to [email protected] so we will be able to check it. Thank you ! | |
03-04-2011, 16:53 | #3 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Africa
Member: 181277 Status: Offline Thanks Meter: 84 | Quote:
http://forum.gsmhosting.com/vbb/f296...-done-1219237/ | |
The Following User Says Thank You to medie For This Useful Post: |
03-12-2011, 10:59 | #4 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Dubai
Member: 45561 Status: Offline Thanks Meter: 59 | Quote:
module v3.79 Device: Alcatel-209X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 353923030000000 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 chip: 0011:717C:A00C status: 01 warning: unknown or damaged hardware boot packet size: 0400 error: bootcode load error: A0 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: wrong answer: C4 error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 37 sec Remove/Install battery now ! | |
The Following User Says Thank You to Mansoor For This Useful Post: |
03-12-2011, 13:16 | #6 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: UGANDA Age: 50
Member: 126167 Status: Offline Sonork: 100.1591387 Thanks Meter: 5,128 | Dont forget to use your FIrst Magic (tactics) , works well. . Br HASSAN MABROUk-GSM UGANDA Quote:
The Following User Says Thank You to hassanjinja For This Useful Post: |
03-12-2011, 20:13 | #8 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | style up man Quote:
style up man tofemba | |
03-13-2011, 09:24 | #9 (permalink) |
Freak Poster Join Date: Aug 2007 Location: kampala uganda Age: 41
Member: 566014 Status: Offline Thanks Meter: 5 | This HW can not be done by infinity mybe diffrent box Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 chip: 0011:717C:A00C status: 01 but for this one is ok infinity can unlock itPress and HOLD Power button now !19200 fixedConnecting, wait...Initializing [6223:8A05:8A00]...CPU: MT6223chip: 0011:4138:A00Cstatus: 01boot packet size: 0400 |
03-13-2011, 18:37 | #10 (permalink) |
Member: 126167 Status: Offline Sonork: 100.1591387 Thanks Meter: 5,128 | Fun and Learn , try to figured out The T.P. Special Thanks, Goes To HAMZA aT ARUA PARK Near Katumwa Sports center For this T.P Br HASSAN MABROUk-GSM UGANDA Last edited by hassanjinja; 03-13-2011 at 18:45. |
The Following 2 Users Say Thank You to hassanjinja For This Useful Post: |
03-14-2011, 10:46 | #11 (permalink) | |
No Life Poster Join Date: May 2008 Location: Bermuda Triangle
Member: 776382 Status: Offline Thanks Meter: 105 | Quote:
The Following 2 Users Say Thank You to kfkevin For This Useful Post: |
03-17-2011, 05:43 | #12 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Kewempe Bombo rd
Member: 245586 Status: Offline Thanks Meter: 18 | [QUOTE=hassanjinja;7071414]Fun and Learn , try to figured out The T.P. Special Thanks, Goes To HAMZA aT ARUA PARK Near Katumwa Sports center For this T.P Br HASSAN MABROUk-GSM UGANDA[/QUOT Big up HAMZA ,,, But i personary have failed to unlock ot-209 ,i have connected to the tp made cutts but nothing phone doesnt but someone show as what he type of wire to put in the hole |
03-17-2011, 14:41 | #14 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 53
Member: 79796 Status: Offline Thanks Meter: 51 | 0t-209 unlocked without tp. & wihout problems COM14 [VCP0] selected module v3.73 Device: Alcatel-209X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6D45:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76T provider: 209X-2BVNRS1 customization: CM76CYB2 customization: XM76CYB2 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM76CYB2 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-209X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20110317-143811.B0X.bin Finished, time used: 1 min 27 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to bvj For This Useful Post: |
03-17-2011, 19:53 | #15 (permalink) |
Member: 245586 Status: Offline Thanks Meter: 18 | @bvj Hi bvj... you mean u have unlocked it without making tp like ot-203x, ? That cant be pls tell us which cable have you used that of ot-203x or that of 208x |
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A | sosin | Alcatel & TCL Old Models | 0 | 02-13-2002 03:47 |
Alcatel BE$ pinouts | GSM Coolhawk | Alcatel & TCL Old Models | 0 | 12-08-2001 15:44 |
NOKIA, ALCATEL EEprom site | Orbital - GSM | GSM Mobile Links | 0 | 04-09-2001 10:31 |
Alcatel One Touch cable needed!!! | tati | Alcatel & TCL Old Models | 0 | 05-17-1999 22:05 |
