Old 04-04-2014, 10:21   #1 (permalink)
Member: 1511197
Thanks Meter: 17
my infinity box not work
please help me sir how use infinity box
Old 04-04-2014, 21:58   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
The Following User Says Thank You to YellowBoss For This Useful Post:
Page generated in 0.17452 seconds with 8 queries
