02-16-2016, 18:48 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 51
Member: 69514 Status: Offline Thanks Meter: 66 | RCA tab stuck When I try to formate it I got following error , Card found : S/N : , v0129 Chinese Miracle II [MTK module] v 1.40 Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA03 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT8127_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 004500DE009400930076005000080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8D DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x004D , [MNAND] mNAND [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/00 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! How to solve it? |
