09-03-2015, 11:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | MyPhone Agua Iceberg Mini SCATTER Problem I have here MyPhone Agua Iceberg Mini Scatter problem read back SCATTER FILE PRELOADER 0x0 { } MBR 0xC00000 { } EBR1 0xC80000 { } __NODL_PMT 0xD00000 { } __NODL_PRO_INFO 0x1100000 { } __NODL_NVRAM 0x1400000 { } __NODL_PROTECT_F 0x1900000 { } __NODL_PROTECT_S 0x2300000 { } __NODL_SECCFG 0x2D00000 { } UBOOT 0x2D20000 { } BOOTIMG 0x2D80000 { } RECOVERY 0x3380000 { } SEC_RO 0x3980000 { } __NODL_MISC 0x3F80000 { } LOGO 0x4000000 { } EBR2 0x4300000 { } __NODL_EXPDB 0x4380000 { } ANDROID 0x4D80000 { } CACHE 0x5C580000 { } USRDATA 0x64380000 { } __NODL_FAT 0xE4380000 { } __NODL_BMTPOOL 0xFFFF00A8 { } Read Factory File Operation : Read Flash [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 30000111394736314DDE0032FB9015B6 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 29G61 [eMMC] : FLASH_CID : 11010030313647393200DE4DB61590FB [eMMC] : FLASH_LEN : 0x00000003AB400000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : MyPhone ProdName : MyPhone Agua Iceberg Mini ProdModel : MyPhone Agua Iceberg Mini Device : MyPhone_Agua_Iceberg_Mini AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_s9311.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / s9311 / EMMC FW Size : 1315 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6589__MyPhone__MyPho ne Agua Iceberg Mini__MyPhone_Agua_Iceberg_Mini__4.2.1__ALPS.JB2.M P.V1.2\ All done! Write Flash Operation : Flash [ v1.27 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 30000111394736314DDE0032FB9015B6 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 29G61 [eMMC] : FLASH_CID : 11010030313647393200DE4DB61590FB [eMMC] : FLASH_LEN : 0x00000003AB400000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! |
09-03-2015, 11:35 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Error mean incompatible HW info inside preloader, upload it ( called preloader_...bin ) Will check it more deep. Or you can do it by yourself - Init Preloader in Extra tab, select that preloader. In log you will see all. |
09-03-2015, 11:39 | #3 (permalink) | |
Member: 3468 Status: Offline Thanks Meter: 308 | Quote:
User selected Preloader file : preloader_s9311.bin Operation : Init Preloader [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 30000111394736314DDE0032FB9015B6 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 29G61 [eMMC] : FLASH_CID : 11010030313647393200DE4DB61590FB [eMMC] : FLASH_LEN : 0x00000003AB400000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Flash Info : FlashID [0] CID : 000000000000000000 , Name : FlashID [1] CID : 90014A484147326504 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 000000000000000000 , Name : FlashID [3] CID : 000000000000000000 , Name : STORAGE : BL NOT support this eMMC! Select Correct One! | |
09-04-2015, 08:26 | #6 (permalink) |
Member: 3468 Status: Offline Thanks Meter: 308 | preloader links https://drive.google.com/file/d/0B7l...ew?usp=sharing |
09-05-2015, 10:44 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I've checked that file. It build with errors , that is reason why not shown all info. You can flash it via SPFT for now, will think about "skip check" option or handle such cases in next versions. |
