01-08-2010, 03:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | Myphone b50c pin-out here COM73 [VCP0] selected module v3.00 Device: MyPhone-B50C Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:318D:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000000:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: H616B128_MYPHONE_CAM_70NM_PCB01_GPRS_MT6223_S00.H6 16B128_BT_IMG_V1_0_0.BIN project-id: H616B128_BT_IMG_V1.0.0, 00000000 code offset: 00000000 ffs offset/size [01]: 00E80000/00180000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00E80000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MyPhone-B50C_H616B128_MYPHONE_CAM_70NM_PCB01_GPRS_MT6223_S 00.H616B128_BT_IMG_V1_0_0__ffs... file saved: C:\Program Files\InfinityBox\MModule\MyPhone-B50C_H616B128_MYPHONE_CAM_70NM_PCB01_GPRS_MT6223_S 00.H616B128_BT_IMG_V1_0_0__ffs_20100108-102922.B0E.bin flash: 98000300000000:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000000:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 57 sec Remove/Install battery now ! |
B50c pin-out here | ayhen42 | Infinity-Box | 0 | 01-08-2010 03:30 |
MyPhone T22 pin out need help | ner21 | Chinese Cocktail | 1 | 06-07-2008 09:20 |
locosto cable pin out here!! (my411x) | datalife2000 | SMTi | 1 | 12-29-2007 19:24 |
All Chinese Pin Out Here | DYNET | Chinese Cocktail | 1 | 10-14-2007 09:31 |
Chinese cable pin out here | .:Nadim:. | Infinity-Box | 4 | 09-30-2007 10:01 |
