07-05-2008, 06:57 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | >>> MyPhone S21 successfully unlocked and pinout here <<< globe ntework locked br keaelite |
The Following 2 Users Say Thank You to keaelite For This Useful Post: |
07-06-2008, 04:57 | #9 (permalink) |
Freak Poster Join Date: Nov 2006 Location: pinas
Member: 382268 Status: Offline Thanks Meter: 16 | just tested today 2pcs s21 after unlock.... insert sim in smart..........@ thread starter how did u manage the insert sim??????thanks COM5 [VCP0] selected Device: MyPhone-S21 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 chip: 0011:4D31:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4EF80 CDF.[TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN_85FEEF84].rpl identification#1 detection finished device-id: 4EF80CDF identification#1 protocol ver: 04 ver. sw1: TINNO23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736 _MP_FMCAM-FTP_V0_07.BIN ver. sw2: T01_23.07A.W0736.MP.FMCAM-FTP_V0.07, 7B10017A ffs offset/size: 00800000/00800000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... ............................. lock area found ............................. lock area found Patch required data Done Special operation... Special operation Done Write... flash: 01227E22202200:2AEA0000000000 flash: 01227E22202200:2AEA0000000000 Write: lock-area-1 flash: 01227E22202200:2AEA0000000000 flash: 01227E22202200:2AEA0000000000 Write: lock-area-4 Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\system_log_4EF80CDF_TINN O23_07A_PCB01_GPRS_MT6223_S00.T01_23_07A_W0736_MP_ FMCAM-FTP_V0_07.BIN_85FEEF84_20080706-113120.B0X.bin Finished, time used: 148 sec Remove/Install battery now ! |
07-06-2008, 05:23 | #10 (permalink) | |
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | Quote:
br keaelite | |
07-07-2008, 04:33 | #12 (permalink) |
Member: 382268 Status: Offline Thanks Meter: 16 | check this sir rakishi,try this this my back files http://rapidshare.com/files/12775932...54504.B0M.html |
The Following User Says Thank You to berks For This Useful Post: |
07-07-2008, 11:10 | #14 (permalink) |
Freak Poster Join Date: Jul 2004 Location: philippines Age: 45
Member: 75776 Status: Offline Thanks Meter: 16 | i allready unlock 2 pcs 1 hour ago but after unlocking done phone insert sim in smart,TNT and suncell..... whewww how to solve this problem???????? |
>>> MYPhone T22 DUO lock code done and PINOUT HERE <<< | keaelite | Infinity-Box | 10 | 06-22-2009 19:22 |
>>> Post Here All SoftBank Phones Successfully Unlocked by UST Pro2 <<< | nasirahmed | UST Pro II | 2 | 06-19-2009 09:54 |
MyPhone T11 format ok and pinout here | keaelite | Infinity-Box | 1 | 09-27-2008 07:23 |
>>> N82 lock code done by infinity and pinout here <<< | keaelite | Infinity-Box | 1 | 07-05-2008 11:26 |
>>> GOT MOTO: Successfully UNLOCKED <<< | RNC_EBM | Motorola P2k | 14 | 12-26-2006 19:23 |
