06-04-2008, 07:48 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Another S700 No display after flash . . . I have face again S700 in dead condition. As said my client before phone goes to dead condition phone is restarted & sometime off autometically. I receive this phone in dead condition. I flash the phone from download file in support area. After complete flash phone is alive but disply is only black. Also i face this problem many many day's before. & that time I can't check the phone with another working display.....but this time i do it with another working display from working phone. As i said u that phone can't show any resulation on the screen only BLACK. But phone is working fine also Incomming & Outgoing is OK. But problem remain in display . . . . ? sO what is the solution for this phone . . . ? Here is the phone flashing LOG. Code: Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.22 S/N: ***X:0X0X Wait... Device: Spice S700 Done Loading file v.02... Spice-S700_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E_0608_V82_2007-06-12_En.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN ver. sw2: 7S-7311-IN00-001-R1E, 00000000 detecting languages... Languages: En COM11 [VCP0] selected Device: Spice S700 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:1141:43F4 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN ver. sw2: 7S-7311-IN00-001-R1E, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E.BIN]_20080604-120111.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 98004900000002:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 289 sec Remove/Install battery now ! |
06-04-2008, 12:38 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, I think that it's quite easy to understand problem reason, but anyway, here is an explanation: 1. phones (even with the same name) may have different components installed (f.e. different LCD types). for each type of hardware it's need to use firmware that support your hardware (the same stuation like your PC and drivers). If you have no drivers you can not use new hardware with your PC. Please, confirm this step, is it enough clear explanation or not ? 2. when you flash phone with firmware that do not have support for your LCD you can get phone semi-working (f.e. problems with LCD) due to firmware that you have used is not suitable for your LCD type Please, confirm this step, is it enough clear explanation or not ? 3. to solve this problem you must use another firmware that has support for your hardware. You can try to use firmware with similar firmware version, f.e. other firmware files like *ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S* 4. we have several flash files in support are that you can try to use: \flashfiles\IMobile\510\IMobile-510_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1H_En_Th_Cn.B0M.bin \flashfiles\IMobile\510\IMobile-510_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-THS0-0-R1R-B_En_Th_Cn.B0M.bin \flashfiles\IMobile\CE0889\IMobile-CE0889_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-INS0-0-R1B-3__En_Ml_Id_Th_Cn.B0M.bin \flashfiles\LG\KG195\KG195P64-ARB-V10a-***-XX_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin \flashfiles\LG\KG195\KG195P64-ESA-V10e-***-XX_OCT-31-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332AA00-001-R1D_En_Ml_Id_Vn_Th_Cn.B0M.bin \flashfiles\Spice\S700\Spice-S700_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S-7311-IN00-001-R1E_0608_V82_2007-06-12_En.B0M.bin One more way to solve this kind of problems: We always ask users to make flash backup from different working phones and send to us, so we can upload more files in Infinity-Box support area. If you send one file and your friend send to us one file etc. etc. we will have in 1 week a lot of files in support area for different hardware, and you will be able to solve all your problems easily. |
06-04-2008, 12:50 | #4 (permalink) |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Thankx for the deep & detailed information about it. I don't forgot it. & remember my friend I don't like u in angry mood. So wake up & change ur mood. Also i try to flash the phone with these file & post here result. Thankx. |
06-04-2008, 13:23 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, I am absolutely not angry on you, I have no reason for this. You have made good problem description (like not many people can do) and you have asked advice in situation that really require an advice (in compare with many other questions like "oh... I am lazy to read documentation and I can not see pinout for Sagem-my150x" etc.). Today I just understand one important thing: even people with more than 10 years of experience "as an Enginners" may have zero knowledges. It's the only reason why I make my explanation so detailed that even 3-years baby can understand it. In current thread I have made explanation not for you (it's a fact) because if I will need to explain it only for you (I see that you have your own brain and you can think, in compare with many other people) I could make only several words explanation, but my explanation was for many other people who can not use their heads for direct usage (thinking) but use it only for other useful purpose (eating). I am really want to say you "Thank you very much". You have made today really detailed problem explanation and as a result you have got detailed answer. Let's hope that other people will see on your post and will try to make in future so detailed explanation of their problems due to in fact that 90% of answer is a good asked question. Let's hope other people follow you. |
06-04-2008, 15:16 | #6 (permalink) | |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
As u say it is a real fact. But people don't understand this thing's. Anyway i download that file & post u result very soon. Also once again Thankx For more more detailed info. | |
06-04-2008, 17:28 | #7 (permalink) | |||
Member: 343326 Status: Offline Thanks Meter: 1,463 | Not luck for me Infinity Team. Here is flash log of i download from support area. IMobile-510_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S-7311-THS0-0-R1H_En_Th_Cn.B0M Quote:
IMobile-510_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S-7311-THS0-0-R1R-B_En_Th_Cn.B0M Quote:
IMobile-CE0889_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S-7311-INS0-0-R1B-3__En_Ml_Id_Th_Cn.B0M Quote:
I flashed with this 3 file. Also phone is on with all 3 flashes complete. But common problem is display is WHITE. | |||
06-04-2008, 19:06 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Try to use 2 rest files with similat firmware (see my previous post). if it will be the same results after flashing this means that tho only way exist to repair your phone: need to find another S700 with the same LCD type as in your phone and read flash from that phone. Also if you have original backup of your phone this may helps too. It will be need to write back original backup and try to make "format ffs" in "safe" or "complete" mode to make phone alive. |
06-08-2008, 10:28 | #9 (permalink) |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Not work . . . . Also i try to flash the phone with backup file but not done. In my view when i receive from my customer he went out another shop & another technition try to flash this phone that's why after write back file phone is in white display mode. And another shocking point is i send this phone to Spice service center. He also return back the handset me & say the phone is caan't repair. Any improvement for this problem Infinity team. Thankx in advance. |
06-09-2008, 06:50 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | There is only one method to repair "white screen" for this phone: find another phone with good firmware and the same LCD type for flash reading. |
06-09-2008, 09:58 | #11 (permalink) | |
This version also not match with this phone. OR might be it is not competible for this LCD . . . Not to worry about that. I return the both phone to the client. | |
07-02-2008, 11:13 | #12 (permalink) | |
Freak Poster Join Date: Jan 2008
Member: 693812 Status: Offline Thanks Meter: 25 | S 700 only show welcome LOGO Quote:
a60 no display after flash | softmaster | E-Gold Based Phones | 1 | 07-06-2004 22:55 |
****t720 with no display after flashing!!**** | infogsm | Motorola P2k | 7 | 02-03-2004 03:49 |
v200 no display after flashing | raid | Trident/AGERE Platform | 0 | 11-22-2003 02:48 |
GD55 no display after flashing | anthony cheah | Panasonic | 7 | 08-20-2003 20:07 |
3310 v 3.24 no display after flash | Ledos | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-04-2001 13:02 |
