N5160 restart now dead! I have here china phone model N5160 dual sim History: restarting when sim is inserted, according to the owner she dropped it. I tried safe format no luck full format no luck format whole flash chip now dead! Logs: Code: Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe UploadMB.com |
need help on this. I need flash file to recover the phone TIA! |
hello! load backup with you have as "firmware" and write it back to your phone. |
I've tried it but no luck hope you can check my uploaded back firmware. TIA! |
hello! what means "no luck"? can you post log of flashing using your original backup file? |
No luck means it doesn't work never powers on the phone. here the logs: hope you can help me or send me a good or working file maybe the firmware file is already damaged. TIA! ==== [7/26/2010 1:20:08 PM] ==== COM5 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12__fullflash_20100715-115308.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4903:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer : wrong answer after chip id request flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 06.06.2010): N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: N5160_2019_SIX_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E20000/001E0000 rom info structure: 2nd [standard] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 18 sec Remove/Install battery now ! |
hello! unfortuantely, this is very rare firmware, we dont have anything even close in our files collection |
