N73-1 pinout 1 Attachment(s) COM3 [VCP0] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BD41:41E4 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: V2.0628.0.0.1 Version: NokiaN73(11) detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 216 items cleared: 197 of 216 building list... done items remains: 1 Finished, time used: 151 sec Remove/Install battery now ! |
hello! thank you for sharing this with us!!! |
i need help to connect cable L14E with N73 with power to batt. connector becuse when i connect the battry connector make red led off, thanx in advance. |
you must be used wrong polarity double check this |
Positive in the positive and negative in the negative. But to no avail. pinfinder it can't read the rx and tx. if i chose from list from (InfinityBox PinFinder) program and run (ChineseMiracle) no response. plz help me how i can connect it. |
hello! can you check if your phone is MT62xx MCU based |
hello! you can do this without disassembling phone by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software (mt62xx based) |
[QUOTE=InfinityHelp;4162621]hello! you can do this without disassembling phone by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software (mt62xx based)[/QUOTE Thank you very much, Mr. I noted at the poles connect any type of phone on the pinfinder extinguished, the lamp Even when connected with pinfinder on output2, the Nokia 3110 i noted the red lamp turn off. Is the problem of Pinfinder? |
Hello, sir Please Sir Please help me in the operation of the pin finder it whether or not the failure. |
Hello, Please, check PinFinder according to "SelfTest" chapter from PinFinder manual. What is the results ? |
