Old 11-02-2007, 20:53   #1 (permalink)
Member: 579761
Thanks Meter: 12
n73music edition
infinty theam i want pinout 4 thise phone
Old 11-02-2007, 22:29   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Ok, it's not a problem. I have prepared special instruction how to find pinout especially for your phone:
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 11-03-2007, 01:34   #3 (permalink)
Member: 579761
Thanks Meter: 12
inon the chipe write N73 RH-64
BUT THE PHONE LIKE n73music edition
Old 11-03-2007, 12:25   #4 (permalink)
Member: 130995
Hello,
Here is solution for you: http:///vbb/showpo...62&postcount=2
n73 and n73music deepaksawdia Nokia Hardware & Hardware Repair 5 09-06-2009 08:03
Can normal edition N73 support music edition N73 firmware? my toh HWK 8 07-15-2009 17:33
1. Menu -> Settings -> Network Setup -> APN -> APN 3 -> Edit -> Enter 0000 -> EDIT "A lukasartsDon NEC 1 03-28-2005 13:14
PPM edit? ok What about mcu editing? excespeace Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 09-17-2002 23:14
LogoManager Business Edition and other special editions... GeeZuZz Nokia Multimedia 15 08-09-2002 22:19
Page generated in 0.16640 seconds with 9 queries
