Old 06-01-2010, 11:31   #1 (permalink)
Member: 496386
Thanks Meter: 6
G5 33+ flash problem
sir plz help me
here log
COM18 selected
module v3.11
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0803:0004
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:FFFFFF00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
can't detect ffs/eeprom record name location
error: ffs/eeprom detection failed: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
done
warning: can not detect firmware version
if software freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting firmware build...
done
detecting product-id...
done
detecting languages...
error: can't detect language parameter #1
warning: can not detect language names
if software freez: make "Find language names (slow process)" unchecked and repeat operation.
Finished, time used: 2 min 32 sec
Remove/Install battery now !
Old 06-01-2010, 21:01   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
flash is empty.
someone erased it.
Old 06-03-2010, 04:14   #3 (permalink)
Member: 496386
Thanks Meter: 6
sir ji
plz tell me it hardware falt ya software and in which falty ic
i try to flash another ok set but error massge Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
plz tell me how can do it
Old 06-04-2010, 19:48   #4 (permalink)
Member: 148515
hello!
just ignore this message and flash your phone with correct flash file
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.18662 seconds with 9 queries
