05-02-2009, 14:39 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: egypt Age: 34
Member: 209407 Status: Offline Thanks Meter: 49 | n82y+ whitw screen log inside ok log the log when i am repair scurtiy aria COM21 [Serial2] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5203:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBA3Z01_8_5_1_ 5T06M0428_M510C.BIN ver. sw 2: LBA3Z01.8.5.1.5T06M0428_M510C, 00000000 ffs offset/size: 00E00000/001E0000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89880F00010001:89880F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done Finished, time used: 72 sec Remove/Install battery now ! |
05-03-2009, 00:24 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try this eeprom file: [bin] flashfiles/ChineseMiracle/_MT6225/eeprom/LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBA3Z01_8_5_1_ 5T06M0428_M510C__ffs_01.B0E.bin |
05-03-2009, 18:22 | #7 (permalink) |
Member: 209407 Status: Offline Thanks Meter: 49 | this log after write epprom COM21 [Serial2] selected module v2.81 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5203:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBA3Z01_8_5_1_ 5T06M0428_M510C.BIN ver. sw 2: LBA3Z01.8.5.1.5T06M0428_M510C, 00000000 ffs offset/size: 00E00000/001E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Eeprom/ffs flash: 89880F00010001:89880F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 269 sec Remove/Install battery now ! and result steel white screen |
z300 dont work - log inside 9.71 | hridaya | Cruiser Suite | 4 | 12-04-2006 04:54 |
k700i whitw screen also cant customize fs plz help | Mobiles4Less | Cruiser Suite | 4 | 05-08-2006 06:19 |
nokia 2300 whitw screen after writing the pm | onu | Nokia Digital Core Technology 4 ( DCT-4 ) | 21 | 03-02-2005 16:07 |
