03-02-2010, 10:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: tunis,tunisia Age: 48
Member: 10396 Status: Offline Thanks Meter: 32 | n88 error: can not finalize test mode i want to make calibration touchscreen for this n88 but always communicatiob problem infinitybox modified with shortcutiing diode ans when i power on enought the time n88 stay in nokia logo but cannot enter a test mode COM3 [VCP0] selected module v3.09 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_Q083_SX0 2_00_V02__fullflash_20100301-183810.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B203:000B status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 2 min 38 sec Remove/Install battery now ! plz any help ? |
03-02-2010, 20:24 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, Is it possible to power-on phone completely from PinFinder (I mean just power-on, w/o software) ? Also, you can try to make this: 1. format ffs in "complete" mode 2. power on phone 3. power-off phone 4, try to make calibration again |
03-03-2010, 17:05 | #4 (permalink) |
Member: 10396 Status: Offline Thanks Meter: 32 | COM3 [VCP0] selected module v3.09 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_Q083_SX0 2_00_V02__fullflash_20100301-183810.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B203:000B status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6225*Qج]@€€€€€€€€€€€€€€€€€€€ Date: 2006.06.14€€€€€€€€€€€ Version: ±.0€€€€€€€€€€€€€€€€ Version: M>»25_ù¸8»كSى0»_00_v02€€€€€€€€ Version: M›»›5_GEMIîIےHW€€€€€€€€€€€€€€ 67 byte(s) read warning: wrong packet cs imei: 33D724828D7509 warning: wrong packet cs connection Ok 512 byte(s) read 219 byte(s) read warning: wrong packet cs reading data #2... warning: wrong packet cs reading data #3... warning: wrong packet cs can't read required data or wrong firmware file selected, select correct file ! error: operation failed ! Finished, time used: 30 sec Remove/Install battery now ! this is the error message and his firmware loaded |
03-03-2010, 17:06 | #5 (permalink) |
Member: 10396 Status: Offline Thanks Meter: 32 | COM3 [VCP0] selected module v3.09 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_Q083_SX0 2_00_V02__fullflash_20100301-183810.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B203:000B status: FF Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: ح\؟2»7lگه¸5€€€€€€€€€€€€€€€€€€€€€€€€€€ Date: 20¸6.06؟1ڑ€€€€€€€€€€€€€€€€€€€€€€€€ Version: 1؟0€€€€€€€€€€€€€€€€€€€€€€€€€€ Version: س’غ؛ےG¸¼3سط02_0¸ك~ک»€€€€€€€€€€€€€€€€€€€€€ہ€€S U Version: ك™»5كشjç؟êاu0p`@ہ€€€€€€€€€€€€€€€€€€€€Me 67 byte(s) read warning: wrong packet cs warning: wrong packet cs imei: EEF585ECCF750B connection lost error: operation failed ! Finished, time used: 36 sec Remove/Install battery now ! another error connection lost |
error: can not finalize test mode | sidramobilecare | Infinity-Box | 3 | 01-27-2010 21:20 |
error: can not finalize test mode | mswmkm | Infinity-Box | 8 | 11-23-2009 16:57 |
how can i flash motorolla phone which can not enter TEST MODE? | kwasasco | Motorola P2k | 1 | 07-12-2008 08:50 |
Z310 can not Leaving test mode!!!!! | kifah | Universalbox | 4 | 09-06-2007 09:05 |
SGH E800 can not get test mode | enrocas | NSPRO | 2 | 04-15-2005 11:01 |
