n91 china dead hi i receive n91 for this pb : when i receive a message i'm not founded in the inbox i tried to flash but phone dead n91 RM-42 IC : 661U-RM42 FCC ID:PYARM-42 COM1 selected Device: Autodetect Checking data, wait... Action: Flash write Write: Firmware Skip: Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6219:8A01]... Release Power button now ! Boot Done Initialize... detecting chip[00] in region[00]... flash: 01227E22202200 flash: 29EA0000000000 flash: AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb total number of flash chip detected: 01 Initialize Done Set baud... 115200 Set baud Done Check space... operation mode: Complete detection mode device parameters autodetection in progress.. detecting chip[00] in region[00]... flash: 01227E22202200 flash: 29EA0000000000 flash: AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb total number of flash chip detected: 01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200 flash: 29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. Err: device identification detection failed, no any information found flash: 01227E22202200 flash: 29EA0000000000 reading [eeprom]... file saved: backup_eeprom_20070604-153402.B0E.bin Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 01227E22202200 flash: 29EA0000000000 Write: Firmware Write Done Finished, time used: 1470 sec Remove/Install battery now ! phone now dead. any solution plz to revive this phone ? |
1. check phone hardware 2. use other firmware for flashing 3. read this: D:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm |
hi thx for replay but i found only one firmware in the support for n91. |
try other firmware files or find other the same good phone for flash reading |
and this my log text : COM1 selected Device: Autodetect Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6219:8A01]... Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200 flash: 29EA0000000000 flash: Amd, AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... operation mode: Fast detection mode device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200 flash: 29EA0000000000 flash: Amd, AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200 flash: 29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification .damaged firmware .damaged hardware detection phase #3... .....................error: unexpected termination/freez: 00540000 detect device parameters finished Finished, time used: 92 sec Remove/Install battery now ! |
i flashed him with n91i flash file but always dead and i reflashed him with n91 and always dead COM1 selected Device: Autodetect Checking data, wait... advanced flash detection active Action: write flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6219:8A01]... Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200 flash: 29EA0000000000 flash: Amd, AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... operation mode: Fast detection mode device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200 flash: 29EA0000000000 flash: Amd, AMD/Fujitsu std [0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200 flash: 29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00700000 Detected eeprom address is non-standard: 00700000 If you are not sure that detected address is correct: 1. press "NO" right now 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom address confirmed by user detecting eeprom size... eeprom size: 00900000 eeprom chip: 00 eeprom area detected[00000000]: 00700000-00FFFFFF detect device identification, method #1... detection phase #1... protocol version: 0004 2nd [standard] (or higher) generation model detected version sw1: CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN version sw2: WOLF_LSM_112_061025_SS0_OV0_SP64_CTF_RU detection phase #3... .................................................. .............. detect device parameters finished flash: 01227E22202200 flash: 29EA0000000000 reading [eeprom[CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN]]... file saved: backup_eeprom[CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN]_20070605-112241.B0E.bin Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 01227E22202200 flash: 29EA0000000000 Write: Firmware Write Done file saved: backup_system_log[CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 5_SS0_OV0_SP64_CTF_RU.BIN]_20070605-114332.B0X.bin Finished, time used: 2463 sec Remove/Install battery now ! |
your problem here : CKT26_05C_PCB01_GPRS_MT6226_S01.WOLF_LSM_112_06102 Your phone has chip MT6219, try to find out flash file with MT6219 not MT6226 can you post picture your phone? |
in this situation need to rad flash from similar phone and write into yours phone. |
