Old 11-15-2008, 01:37   #1 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
N95 (T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A) is Dead..
hi supporters and all..
after firmware refresh phone is dead now..pls check the log...
COM17 [VCP2] selected
module  v2.69
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:2866:E067
high speed disabled
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:76737200000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 76657273696F6E3A30320000000000000000000000000000
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detection phase #1....
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
can't detect fat record name location
error: ffs element #1 detection failed
detecting ffs structure pass 2...
error: ffs element #2 detection failed
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Finished, time used: 173 sec
Remove/Install battery now !
Old 11-15-2008, 02:00   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
module  v2.69
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
.damaged firmware
.damaged hardware
ffs chip: 00
i have the org. backup but after flashing again phone is still dead..
eeprom log..
module  v2.69
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
.damaged firmware
.damaged hardware
ffs chip: 00
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20081115-025718.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
Finished, time used: 315 sec
Old 11-15-2008, 02:07   #3 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks Meter: 905
try this one its back up flash file and the epprom of a chinese nokia N95
T6226_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP _V3_F3_1.BIN
click here
let me if it works
good luck
shehab
The Following User Says Thank You to gsm2start For This Useful Post:
Old 11-15-2008, 02:27   #4 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
eeprom log..
module  v2.69
skip: Firmware
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
.damaged firmware
.damaged hardware
ffs chip: 00
reading: eeprom...
Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
module  v2.69
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
.damaged firmware
.damaged hardware
ffs chip: 00
phone is oki now.. with orj eeprom and flash file..
eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A.B IN]_20081113-015948.B0E
flash[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A.B IN]_20081113-001035.B0M
Old 11-15-2008, 02:30   #5 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks Meter: 905
good to know
regards
Old 11-15-2008, 02:31   #6 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
click here
let me if it works
good luck
shehab
thanx sir..
i will add to rapidshare to this new flash file.. cause of not exist on support.. supporter would add to support page..
thanx for ur sensetive again...
Old 11-15-2008, 02:39   #7 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
http://rapidshare.com/files/16387626....BIN_.rar.html
b.r.
The Following User Says Thank You to LoveLess For This Useful Post:
Old 11-15-2008, 21:54   #8 (permalink)
Member: 130995
Thanks Meter: 35,228
Hello,
Thanks for link !
We will add this file in support area ASAP.
ub team n95 8g after unlock contact service my phone is dead helllllllllllllllllllllp khalid0909 Universalbox 3 03-28-2009 11:17
Nokia N95 - Is Dead After Unlock PHU KADAR Nokia Base Band 5 ( BB-5 ) 7 11-11-2008 03:59
n95 rm-160 to n95 rm-159 is it possible? $ide$tep Nokia Base Band 5 ( BB-5 ) 2 03-12-2008 23:46
Has anyone supplied bb5team with n95-8gig locked ? Is n95-8g coming soon? Rezn BB5BOX 13 02-25-2008 21:07
Page generated in 0.22744 seconds with 9 queries
