n95 chinese i need cable pinouts 1 Attachment(s) i need nokia 95 chineses pinout any one can help me out it my problem is to find the cable the cable is 18 pin and i couldnt find it in the forum or infinity support area |
n95 pinout 18 pin 1,2-ground 7---tx 9---rx today i tested work done |
Due to a lot of different models with the same name but absoluteley different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 |
yes.................. 1 Attachment(s) :):):):)this Is Your Pin OutAttachment 123175 |
here is pinouts for chinese n95 12 pin phone bottom connector_1x12_mini ___________________________ / 1 2 3 4 5 6 7 8 9 10 11 12\ ----------------------------- phone pin 1 gnd connect to box pin 7 or 8 phone pin 6 tx connect to box pin 3 phone pin 7 rx connect to box pin 2 |
use n95 SLIDER from infinity text file |
many thanks thıs pınout %100 workıng |
I think this post can also be useful http://www.art-service.dn.ua/forum/showthread.php?t=48 |
n95 pinout 18 pin 1,2-ground 7---tx 9---rx today i tested work done thank you this pinout 100% work |
