12-03-2007, 17:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | N95 dead what file to use in the support i see file like CM_Nokia-N95-2sim_N618_PCB01_GPRS_MT6227_S01.1_16m_En_Fr_Ar_Th. B0M.bin but as i know this model is 6228 NAND? any help thx |
12-04-2007, 09:23 | #3 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | i made a mistake i flash it without reading phone version now normally the phone version is like version of flash file any help thx |
12-04-2007, 13:35 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make read info or if phone doesent boot- disassemblle ohone and check what is written on MCU. regarding original phone version: you can always find it in log file. on first operation which you did with this phone. |
12-05-2007, 08:40 | #6 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | where's the phone version ?? Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.60 Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... CM_Nokia-N95-2sim_N618_PCB01_GPRS_MT6227_S01.1_16m_En_Fr_Ar_Th. B0M.bin loaded protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: backup_eeprom_20071203-165002.B0E.bin flash: 01227E22202200:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.830C9EB1.[N618_PCB01_GPRS_MT6227_S01.BIN_C3A0516F].rpl identification detection finished Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished device-id: 830C9EB1 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.830C9EB1._N618 _PCB01_GPRS_MT6227_S01.1.BIN_51959CA1_.rpl file saved: id.830C9EB1.[N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1].ask ASK file created Ok Probably identification data damaged, device id: 830C9EB1 firmware version: N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1 RPL file must be in folder: C:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.830C9EB1._N618 _PCB01_GPRS_MT6227_S01.1.BIN_51959CA1_.rpl Write Done file saved: backup_system_log_830C9EB1_N618_PCB01_GPRS_MT6227_ S01.1.BIN_51959CA1_20071203-171725.B0X.bin Finished, time used: 1856 sec Remove/Install battery now ! COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished device-id: 830C9EB1 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.830C9EB1._N618 _PCB01_GPRS_MT6227_S01.1.BIN_51959CA1_.rpl file saved: id.830C9EB1.[N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1].ask ASK file created Ok Probably identification data damaged, device id: 830C9EB1 firmware version: N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1 RPL file must be in folder: C:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.830C9EB1._N618 _PCB01_GPRS_MT6227_S01.1.BIN_51959CA1_.rpl detecting eeprom area in 1 chip(s)... flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... ................ detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete eeprom element #1 detected ok Finished, time used: 88 sec |
12-05-2007, 13:26 | #7 (permalink) | |
Your software version is in YELLOW color. Btw, just for info: you have used v1.60 but current "ChineseMiracle" version is 2.06. Don't you think that it's good idea to use latest software to avoid many questions ? | |
How To Flash Nokia With Ufs3 And What Files To Use | gatchary | UFS2 + UFS3-Tornadoflasher | 1 | 02-03-2007 16:02 |
P900 - what files to use form support site? | dennt | UFS2 + UFS3-Tornadoflasher | 0 | 08-23-2006 14:57 |
Flash 5140i but what files to use? | pele1 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 01-20-2006 19:00 |
What file to use to debrand v3 | pig | Smart-Clip | 4 | 10-31-2005 23:50 |
8130 r dead . what files to use ? | luckycool | VygisToolbox | 12 | 07-28-2005 14:53 |
