N95 have restart problem but format can not solve it any help here N95 have restart problem but format can not solve it any help here:: i format it and write full flash and eeprom and unlock and write IMEI and do all that but no way when i put a sim into it it will shut down i try more than one sim but it is the same. any thing i can do here ?????? |
i check the hardware of this phone it is new and there is no fault at all inside the phone |
hello! does phone calls 112 without card? at what point it shutdowns? before pin entering, after or? |
i connect it to power supply and see its current it is normal. it shuts down when it looks for network and some times before entring to the main screen. i flash it with flash file from support + erom + unlock + format ( safe & complete ) + write IMEI + change IMEI + try 4 sim cards . so after that i open the phone and looked for something inside and found nothing and i am sure it is new one. |
hello! does phone calls 112 without card? |
now i am at home i will test tomorrow and let u know as i still have the phone at my workshop |
if your set make a call without sim in 112 than its soft problem. if not than its PA problem. BEST OF LUCK, JHON. |
ok it can not make it so i will check pa for it thank u |
