03-14-2009, 09:59 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 655997 Status: Offline Thanks Meter: 9 | N96 (Q7) flashfile needed in the upper left corner Q7 is written back label was torn off can oly see: GSM/GPRS and below S/N:N96 pinout/ connector is 1x12 formatted but cant power:logs ==== log: [3/14/2009 3:30:53 PM] ==== COM7 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0203:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:18A59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... warning: wrong data size at 0x00ECC800, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090314-153604.B0E.bin flash: 98004900000002:18A59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:18A59F00000000 Finalization Done Finished, time used: 325 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! cant perform read fullflash..always error so dont know what firmware it is.. |
03-15-2009, 03:05 | #3 (permalink) | |
Member: 655997 Status: Offline Thanks Meter: 9 | Quote:
it cant read general information heres detailed information.. it says old firmware...what is the compatible firmware for this model COM7 [VCP0] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0203:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #01 in region #00... flash: 98004900000002:FFBFFF00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #03 in region #00... flash: 98004900000002:FFBFFF00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #04 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #05 in region #00... flash: 98004900000002:FFBFFF00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #06 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #07 in region #00... flash: 98004900000002:FFBFFF00000000 flash: Toshiba TV00578002DABD T 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #01 in region #00... flash: 98004900000002:FFBFFF00000000 flash: Toshiba TV00578002DABD T 8Mb detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba TV00578002DABD T 8Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:18A59F00000000 checking area [00000000]: 00000000-007FFFFF... flash: 98004900000002:FFBFFF00000000 checking area [00800000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 01 ffs/eeprom area: 00800000:00600000-007FFFFF detecting ffs/eeprom structure pass 1... .................................................. ...... can't detect fat record name location error: ffs/eeprom detection failed: element #1 detecting ffs/eeprom structure pass 2... .................................................. ...... can't detect fat record name location error: ffs/eeprom detection failed element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 118 sec Remove/Install battery now ! | |
t39 flasher/imei soft and flashfile need! | dollyb | Old Ericsson Phones & Sony Phones | 0 | 03-16-2002 20:29 |
nokia 5146 v5.61 flashfile needed | trafix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 12-01-2001 06:25 |
To CHAVAL - flashfiles needed!!!!! | Winner58 | Old Ericsson Phones & Sony Phones | 3 | 09-04-2001 09:26 |
T10s full flashfile needed ! | wazl | Old Ericsson Phones & Sony Phones | 5 | 05-20-2001 16:38 |
Flashfiles needed | Squesch | Alcatel & TCL Old Models | 1 | 01-10-2001 09:51 |
