n96i rstart after iert sim card problem i have infinty box and uincable i cant conect cabe with n96i 1:rx 2;tx 6;gnd plz help i want corct plan for n96i thanks for replay |
Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
thanks my Dear Friend my fone n96i 2 sim cect p198 6228 inusb pin 6 is gnd can this help you to help me thanks agine |
@ahmed nokia YOUR information can help YOU to help YOU because YOU have YOUR phone on hands but not me ! Please, read again this instruction: http://67.15.194.130/vbb/showpost.ph...37&postcount=2 |
thanks 4 replay iam find it pin 4 tx pin 5 rx pin 6 gnd i have too phone 1 format ok and done and anther thanks i repear on phone but anther i have white screen i read flash in firest phone and writ in sc no repear |
Infinity-Box "Chinese Miracle": How to repair "White LCD", "Black LCD", "no LCD" problems: 1. check phone hardware: LCD unit may be damaged. 2. check phone hardware: LCD flex cable may be damaged. 3. use other flash files for flashing, because exist many different phones with different LCD hardware types so need to use different firmware files and find firmware that work good for your LCD hardware. Select flash file with similar firmware version, phone model name is not important, only firmware version is important. |
