09-09-2007, 00:41 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | <<< N96i shutting off problem,solved by infinty >>>> Nokia-N96i connector_2x5_mini 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 br keaelite Last edited by keaelite; 09-09-2007 at 00:47. |
09-11-2007, 02:40 | #4 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | [QUOTE=keaelite;2700516]just fixed yesterday one N96i shut off when inserting SIM card using COMPLETE FORMAT option,ounce again thanks infinity. Nokia-N96i connector_2x5_mini 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 CAN U HELP WITH CABLE???PLS I NEED ALL DIS FONE WITH READY MADE CABLE..PLS CAN U HELPS??REGARDS.............. |
09-11-2007, 03:10 | #5 (permalink) | |
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | [quote=damabib;2705207] Quote:
u can use the usb of the phone,use the usb connector only then get RJ45 cable. br keaelite | |
09-21-2007, 08:27 | #8 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | N96i Not connecting I followed pinouts above. With keypad ontop and counting from left to right up and down, that is pin1(up), pin2(down) since we have 2x5 mini connector. Correct me if i am wrong.with this connection made this is what i got as result after many trials COM1 [Serial0] selected Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 48 sec Remove/Install battery now ! |
09-22-2007, 06:33 | #12 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Leon
Member: 8804 Status: Offline Thanks Meter: 4 | 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 1 on the phone side connects to TX 2 on the phone side connects to RX 6 on the phone side connects to Gnd 5 on the ??? connects to 10 on ??? <<<< please explain this 10 on the ??? connects to 5 on ??? <<<< and this thank you. |
5130 Call Send recieve then Switches off problem Solved.... | swechacnu | Nokia Base Band 5 ( BB-5 ) | 7 | 01-18-2011 14:48 |
1110i 20s 30s turn off problem solved | charletan | Universalbox | 0 | 04-04-2008 15:43 |
!!!!K600 white screen/pls wait/ shut off problem!!!! | rakishi | Cruiser Suite | 14 | 11-07-2007 23:07 |
E65 Auto Shut Off Success Flash By -ub | GUDO-GSM | Universalbox | 1 | 04-29-2007 13:28 |
sx1 shut off problem | emso | Siemens Hardware Repair Area | 0 | 11-24-2006 22:16 |
