Old 02-01-2008, 02:07   #1 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
N99 China Phone Repaired With Infinity
heres another common problem for china phones.auto shut off when turned on with sim.....
first step look for the pinout
now for safety measures i first created back up just in case....
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:DD5B:B961
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.CD540A26.[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_03.BIN_78F34C65].rpl
New firmware detected:
- make "Repair security area" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: CD540A26
identification#1 protocol ver: 04
ver. sw1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_03.BIN
ver. sw2: BR26_35.03
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [flash[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_03.BIN]]...
warning: wrong data size at 0x00B41C00, retry...
read error recovered
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_03.BIN]_n99_20080131-163753.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_CD540A26_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_03.BIN_78F34C65_20080131-163900.B0X.bin
Finished, time used: 694 sec
Remove/Install battery now !
FORMATTING PROCESS
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: TIANMA_ST7787_2P8_OV7670_MIR_BR26_35.03
Version: BR26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 35868300324502
connection Ok
building list...
done
items to clear: 174
warning: wrong packet cs
154 of 174 items cleared
0 items remains
Finished, time used: 131 sec
CHANGE ORIGINAL IMEI
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: BR26_05C_HW
Software version: TIANMA_ST7787_2P8_OV
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
new imei: 358683003245025
imei verified Ok
Finished, time used: 58 sec
Power off phone now !
FINAL RESULT
Old 02-01-2008, 04:36   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,489
Hello,
Thank you for good test report !
Please, send backup_system_log_CD540A26_BR26_05C_PCB01_GPRS_MT6 226_S01.BR26_35_03.BIN_78F34C65_20080131-163900.B0X.bin
and
files to [email protected]
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 02-01-2008, 04:39   #3 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
ok and thanks for the reply i am now sending it to you.thanks for the updates and more power....
Old 02-01-2008, 06:38   #4 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
i already emailed you and just in case you didnt get my reply heres the link for the files i uploaded
http://www.sendspace.com/file/rshvti
Old 02-15-2008, 16:20   #5 (permalink)
Registered User
ProfiTel's Avatar
Member: 59852
Thanks Meter: 7
same thing here, N99 dual sim,
repair ffs , repair imei - and working !!!
thanks
Deki
Old 06-13-2008, 12:44   #6 (permalink)
Crazy Poster
Member: 588792
Thanks Meter: 14
witch cable do you have
cause i conect cable L10C [2x5] can not detect rx tx
Old 06-14-2008, 02:23   #7 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
actually this was done by me a long time ago and during that time i still dont have pinfinder and i did it manually.just open the unit then solder the rx,tx and gnd points then run the program to fix the phone.btw a hint if youre using the pinfinder then try to press the button switch rx tx or the button beside it coz sometimes pinouts come inverted....
Old 07-16-2008, 11:48   #8 (permalink)
Registered User
Member: 774318
how about slave initialing on display after format this phones please share broo?
5310 china phone dead for infinity box the problem only hung up lilong_lee Infinity-Box 10 12-20-2009 21:56
chines phone repair with infinity is legal or illegal johnysofts Chinese Models & Cloned Phones 2 12-05-2009 11:31
1600 china phone hang, using infinity box...... Redtan_70 Infinity-Box 3 01-07-2009 02:42
SE T668 China Phone Repaired with PINFINITY COMBI alfox Infinity-Box 5 10-24-2008 02:20
China Phone Repairing Solutions cactus Hardware Repair by brands 1 10-17-2007 22:18
Page generated in 0.30165 seconds with 8 queries
