11-16-2009, 07:03 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 453604 Status: Offline Thanks Meter: 33 | Nand chip kg195 COM3 [VCP0] selected module v2.91 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031C0A:F7CA status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 0A loader: 3.0840.00.00 NAND id: 00000000 external ram: 00400000 finalize connection... done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0098:004900000000 [01000000] NAND: 0000:000000000000 [00000000] NAND chip is not installed Initialize Fail Finished, time used: 654 sec Remove/Install battery now ! regards malik. |
11-17-2009, 12:23 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | We are trying to make our dear users so smart as possible. I thought that you will be able to understand the problem reason by yourself, especially because you have a detailed information in operation log. Ok, if you did not understand the problem here is small explanation. If software can not detect flash chip this means that phone do not have flash chip. This means that chip is damaged or other phone part is damaged. So here is an advice from Mr.Infinity (who know nothing) - you must check phone hardware. I hope that this thread is a good example hot to understand what is the problem with phone when you have detailed operation log. |
11-17-2009, 14:15 | #6 (permalink) |
Member: 453604 Status: Offline Thanks Meter: 33 | Dear Sir Infinity,i posted that thread and never got any reply for some time as here u replies as soon as possible,writing that EVEN NOT MR.INFINITY,never means that u know nothing,i always give u respect as our good guide and teacher.we sitting in our stores and making good money just because of ur help.please dont take me wrong and i never mean to hurt u and if i did i'm really sorry for that. regards, malik. |
11-17-2009, 14:48 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you really want to solve a problem urgently, please, read operation log text and for sure in many cases you will be able to solve the problem faster. |
11-17-2009, 15:23 | #8 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Quote:
1. In infinity Box shell 2. select chinies miracle and open 3. Here select AutoDetect 6228-6229 NAND 4. Go on service tab 5. In format option choose "whole flash chip" 6. Click Format After format on your set will be 100% okey post the result DON'T FORGET "THANKS" BUTTON ZK MOBILES OKARA CANTT PAKISTAN 03006955466 | |
The Following User Says Thank You to zubairok For This Useful Post: |
11-17-2009, 19:58 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I think it will be impossible to follow this instruction due to software can not detect NAND flash chip. This means that NAND chip is damaged or bad soldered or any kind of other hardware damage may take place. |
KG195 kg195 "warning charge current over limit:" | ARS.Rehman | LG Hardware Repair | 18 | 05-29-2015 07:22 |
can i replace nand flash chip from another k800? | zonetrichur | Sony Ericsson | 2 | 05-08-2009 05:11 |
how 2 format nand 6228 chip | ayaz ali | Infinity-Box | 3 | 05-17-2008 10:33 |
How to know a 5300b isFlash Chip SEC xxxxxxxx-ATB or Flash Chip SEC xxxxxxxx-ATD? | emicabher | BB5BOX | 4 | 10-04-2007 00:39 |
wanted 6230i NAND flash , camera ic, bt chip | GsmTracer | Wanted Products | 1 | 07-18-2006 05:38 |
