narnia 8088 hi i need to flash narnia 8088 ibought new cables from i-pmart when i connect cable (cect N1000) to phone it shows "usb on" when i connect to box and load firmware it does not detect it at all . any suggestion i need urgently. here is some logs: COM4 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 62 sec Remove/Install battery now ! PS: phone works ok . thank you |
It's cable problem, wrong pinout. You must use correct cable and select correct COM port. Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
@antm, Have you solved? Just bought cables from same supplier and having same problem at this phone... |
