08-05-2008, 14:09 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 412834 Status: Offline Thanks Meter: 215 | ZTC H688 error flash this phone is 2 sim gsm dual on and the problem is always searching on sim 1 mode if sim 2 is normal i want to format it or repair sw first but on infi always show error COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11warning: wrong packet cs 12 13 14 15 16 17 18 19 20warning: wrong packet cs 21 22 23 24 25 26 27error: detection failed (28 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! how to solved my problem sir?????? thx for reply br. |
08-19-2008, 15:14 | #3 (permalink) |
Member: 412834 Status: Offline Thanks Meter: 215 | how to repair sim 2 always searching???? if flash/change imei/format or etc operation on 2nd cpu mode still not work COM2 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. how to boot with cpu 2????? br. |
08-19-2008, 20:44 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! format second phone part, then restore IMEI. to make second MCU boot completly- you must hold power button very long up to 1 minute. Do not release it even if phone will power On |
08-20-2008, 13:10 | #5 (permalink) |
Member: 412834 Status: Offline Thanks Meter: 215 | i have do it sir but every phone want start the phone dead again then infi post error result if phone dead 2nd cpu can flash or other operation how to solved it???? br. |
08-21-2008, 22:27 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice following: 1. desolder diode in main infinity box. (procedure is described in pinfinder user manual. 2. set in phone Silent mode, because sounds take too much power after this is done- repeat procedure |
if any one have ztc zt8089 model flash file | JOHN_JAVED | SpiderMan | 0 | 05-21-2008 13:40 |
Ztc 8380 Not Flash _why? | ..::topnet_gsm: | Infinity-Box | 13 | 05-10-2008 19:53 |
can any one uplaode ztc zt8089 chiness flash file | JOHN_JAVED | Infinity-Box | 4 | 05-06-2008 21:47 |
Ztc Zt-8380 Flash | sarasa | Chinese Models & Cloned Phones | 0 | 05-05-2008 15:39 |
ztc ip 9300 flash file needed | kulvindersingh | Infinity-Box | 3 | 10-29-2007 11:38 |
