05-31-2018, 00:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | nead gpt partition to revevie a dead oppo f1s after some search, i got an advice from a member, he told me that i have a flash " gpt partition " this file can be red from a working phone, then after that i can flash my phone with full flash and revive it. can anyone give this fille ? gpt partition.. log with CM2MT2 : Code: Reconnect Power/Cable! Operation : Write Flash [ v2.00 r3 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :17 [FL] : Set : preloader.bin [FL] : Set : preloader.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : md3rom.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xCB57804C [ 3,18 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM44) MODE : BOOTROM PORT : 44 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_oppo6750_15131.bin EMI : CNT : 0009 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3,00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3,00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393756 : VEN : UNKNOWN | DEV : Q3J97V : RAM : [ 3,00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4,00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 13014E51334A393757 : VEN : UNKNOWN | DEV : Q3J97W : RAM : [ 4,00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4,00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4,00 GB ] EMI : [08] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-31-2018, 10:49 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Device not accept second DA, so, probably there is problems with flash or device itself. Or someone flashed signed preloader with some "enable fuse" code. You can't boot it at all. So, before GPT there is a problem. Have no idea how override it right now. |
05-31-2018, 10:53 | #5 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
Br | |
05-31-2018, 11:20 | #8 (permalink) |
Freak Poster Join Date: Feb 2013 Location: algeria
Member: 1882912 Status: Offline Sonork: 100.1677703 Thanks Meter: 263 | you can try oppo 32gb EMMC: 13014E51334A39375610028E15479359 EMMC: VEN : UNKNOWN | OEM : 4E01 | DEV : Q3J97V EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] https://mega.nz/#!61VlRbyb!SRt_Fottm...DcKsWK9fvRmX0Q oppo 64gb EMMC: 150100524331344D4201E947CAFC138B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RC14MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] https://mega.nz/#!vo8y3JZT!svIx6TzBD...-XNmPoV50ra9lw |
05-31-2018, 11:22 | #9 (permalink) | |
Br | |
05-31-2018, 14:55 | #11 (permalink) | |
Code: Operation : Memory Tool Init [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM44) MODE : BOOTROM PORT : 44 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! thyank you all. | |
05-31-2018, 17:20 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Not sure about rehot will help. There is need to try program it via external emmc hw. Then, if result will be same at boot and no power one - then it CPU. |
02-18-2021, 22:02 | #14 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | as far as i know GUID Partition Table is the so called gpt so why do u need it when the tools can create it corresponding with the scatter files and the preloader partition so in this case you might need to boot it picking settings from compatible emi /preloader because looking at the log it doesnt boot the phone to have acces to emmc if this fails remove isp put it to any jtager z3xjtag,ufi,medusa,riff watsoever try to write corrct firmware after formatting emmc and make sure the firmware is correct some emmc security doesnt allow to flash secure partitions like preloader nvdata nvcfg nvram e.t.c depending on vendors specifications and limitations best practice reprogramm emmc with any jtager thank @jaydi later |
