04-28-2009, 04:45 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | NEC N343i Resetcode successfully fixed COM8 [VCP0] selected Device: Nec N343i Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:98E59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 00005283 Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write Done Finished Remove/Install battery now ! Time used: 18 sec |
The Following 2 Users Say Thank You to zeerik For This Useful Post: |
10-27-2009, 21:57 | #3 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
Help For Unlocking Nec N343i | Mobile Master Pk | NEC | 16 | 01-14-2011 06:15 |
NEC N343i find pinout successful | pethu | PadFinder box | 0 | 07-22-2009 09:11 |
@Hack3r2k nec n343i unlocked?? | Siemens man | FuriouS II | 33 | 11-29-2005 19:19 |
Nec-N343i unlock: looking for beta-testers | InfinitySupport | Infinity-Box | 20 | 11-21-2005 15:40 |
