01-19-2019, 17:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Need boot new CPU 6531E Phone does not start when sim is inserted It gives error illegal use and shutdown I tried to use boot jig but it didn't work Can someone guess boot key or test point short with gnd DP test point short with gnd didn't work |
01-20-2019, 05:47 | #3 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Aricha Ghat, Bangladesh
Member: 1393008 Status: Offline Sonork: C0821FB9 Thanks Meter: 47 | Try to Hold All button same time and connect USB May alllah help you |
The Following 2 Users Say Thank You to mojahiudul For This Useful Post: |
01-20-2019, 13:32 | #5 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Spd 6531e CM2 Sported SPD 6531 E C A ETC...... Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : E000 : NOR Operation : Format FileSystem [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1A7 5262484F9_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
01-21-2019, 03:51 | #6 (permalink) |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | I Already posted but team not seen yet it clearly forum.gsmhosting.com/vbb/f296/request-infinity-team-one-coming-scr-module-if-possible-2549486/ |
01-21-2019, 14:45 | #8 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | I think this is new revision, I have done several brands phones on 6531E CPU, this seems to be new hardware revision. Using test points it connects successfully but doesn't boot UP because of boot key I tried boot Jig and each key and different keys combination , no luck Look like now keypad phoned are coming with secure boot Last edited by khanzada606; 01-21-2019 at 14:54. |
The Following User Says Thank You to khanzada606 For This Useful Post: |
