08-12-2015, 15:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | need by2 m55 invalid sim solution repair security Code: Operation : Repair Security [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 159 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 882CEDFB6ECD9EDB3DEF483D62EA3049 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : MAUI.11B.W11.32.SP.V1.F4 HW : HEXING50_11B_HW IMEI[1] : 251888101011086 IMEI[2] : 251888101011086 Update IMEI[1] to : 35906204350xxxx Done! Code: Operation : Repair Security [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 159 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 882CEDFB6ECD9EDB3DEF483D62EA3049 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : MAUI.11B.W11.32.SP.V1.F4 HW : HEXING50_11B_HW IMEI[1] : 9900012289xxxxx IMEI[2] : 251888101011086 Update IMEI[1] to : 3545090553xxxxx Done! Done! Elapsed: 00:00:33 Reconnect Power/Cable! Code: Operation : Repair Security [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 159 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 882CEDFB6ECD9EDB3DEF483D62EA3049 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6250 SW : MAUI.11B.W11.32.SP.V1.F4 HW : HEXING50_11B_HW IMEI[1] : 35566005167xxxx IMEI[2] : 251888101011086 Update IMEI[1] to : 99000122896xxxx Done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! but still showing invalid sim here is readed firmware Code: Operation : Read Flash [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 159 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 882CEDFB6ECD9EDB3DEF483D62EA3049 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Reading Flash Conent now ... Read Flash now Read Ok , 8388608 bytes read Check and collect compile info File_Info : HEXING50_11B_PCB01_gprs_MT6250_S00.MAUI_11B_W11_32_SP_V1_F4.bin FileVersion : MAUI.11B.W11.32.SP.V1.F4 Saved to : C:\InfinityBox\CM2MTK\Read_out\HEXING50_11B_PCB01_gprs_MT6250_S00.MAUI_11B_W11_32_SP_V1_F4.bin Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
