Need china flash file InfinityHelp code Z224F_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_28_MP_V1_ F4.BIN |
hello! flashfiles/ChineseMiracle/_MT6223/N72i_Z224F_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_28_M P_V1_F4__N72i_16m_En_Ru_Fr_Es_It_Ml_Id_Th_Vn_Farsi _Pt_Ar.B0M.bin |
hello! post full log in text format. data from message window is copyable |
full format 1 COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:3989:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 0170001C261C27:01700000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: FFFFFFFFFFFFFF:90FFFF00000000 flash: FFFFFFFFFFFFFF:90FFFF00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 0170001C261C27:01700000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: FFFFFFFFFFFFFF:90FFFF00000000 flash: FFFFFFFFFFFFFF:90FFFF00000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:01700000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20110112-230234.B0E.bin flash: EC257E25082501:01700000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:01700000000000 Finalization Done Finished, time used: 9 min 40 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
hloo sir InfinityHelp |
If flash chip can not be written - in most cases it's a result of DAMAGED HARDWARE. Please, check phone hardware first ! |
hello! try to resolder or at least heat Flash IC |
