04-23-2008, 09:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | a strange problem.. plz hlp for ztc zt6698 chk thw infinity log below:- asd i pressed the pwr button everything is ok but as i release the pwr button as said by infinity the softwares gives error coz fone stops to consume power. here is the log):- chk here COM46 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:22E2:1A39 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer: wrong answer after chip cfi request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 118 sec Remove/Install battery now !.. wen software said to release the pwr button i did... as this error shown.. bt on the other hand if i do not release the pwr button everything is ok but fone still dead.. do i need to flash the fone... if yes then plz share the full flash for this fone here.. thanx plz hlp me that what shud i do?? oone more thing.. before complete format the fone was consuming.05 amp near bout current.. btu after complete format it doesnt.. Last edited by peter002; 04-23-2008 at 09:19. |
04-23-2008, 09:24 | #3 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | u need not to flash the phone just heat the flash ic slightly and check it again....u will solve ur problem if problem still same then Reball ur cpu and flash ic....from this u will receieve some result sure Good luck Kmax Mobile Repair Gurmandi,Patiala |
04-23-2008, 09:24 | #4 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Gsm World Age: 35
Member: 611165 Status: Offline Thanks Meter: 36 | Initialize... detecting chip #00 in region #00... error: no any expected answer: wrong answer after chip cfi request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail See that errors bro...this is problem in flash chip....rehot or reball flash ic..we are also getting that type of problems....reball flash ic & post results |
04-23-2008, 09:29 | #5 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | before the complete format the fone was dead but was consuming the pwr in sm milli amperes,... but after the complete foprmat the fone got totally dead.. i means it consumes the pwr till i kept the pwr switch pressed but as i relese the pwr button the power consumed is 0.... any idead what shud i do |
04-23-2008, 09:54 | #6 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 see near cpu mt6226 then u found there flesh ic rehoot or rebool ic now com to topic power consuming i also se 9 phone with same models with 1 gb internel memory when i try to format these phone same error comes damage flesh chip and after that phone is going to same poosition as yours so rebool flesh solve you problam rebool and post result there best of luck |
04-23-2008, 11:34 | #7 (permalink) | |
Member: 599037 Status: Offline Thanks Meter: 103 | Quote:
COM46 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:22E2:1A39 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.30CBF139.[MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN_D67C4850].rpl identification#1 detection finished device-id: 30CBF139 identification#1 protocol ver: 04 ver. sw1: MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN ver. sw2: DM402.V007.WMB.2BT.GKW, AFB78329 ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: B0001D00000000:B0001D00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00F00000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00F00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W.BIN]_20080423-155651.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: B0001D00000000:B0001D00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _30CBF139_MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_ WMB_2BT_GKW.BIN_D67C4850_20080423-155741.B0X.bin Finished, time used: 293 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but aftere that the fone is still dead.. what shud i do now?? | |
04-23-2008, 15:27 | #9 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | Ok Bro.. I Read The Full Flash From The Fone And Then I Erased The F;ash Chip And Wrote The Read Flash Agaiun... But Fone Is Still Dead....while Fone Is Using The Power Form The Digital Pwr Source But Not Getting On... Any Idea What Shud I Do??? HERE IS THE LOG FOR THE OPERATION.. COM46 [VCP4] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:22E2:1A39 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: B0001D00000000:B0001D00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80423-180737.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done Area: Firmware flash: B0001D00000000:B0001D00000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 2755 sec Remove/Install battery now ! |
04-23-2008, 19:31 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! now after you repaired hardware, you must restore firmware in your phone. you must find this software version file and flash your phone: MY6226_PCB01_GPRS_MT6226_S01.DM402_V007_WMB_2BT_GK W |
04-24-2008, 20:14 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! it will be better if you start new tread with this question like subject "ztc zt6698 firmware needed" and full version name inside this will be more visable for other users |
i-Pmart BX Series RJ45 Cable Compatible For ZTC ZT6698 For Infinity Box | IPMART | ipmart WebShop | 0 | 07-08-2009 10:50 |
u600 keys very strange problem.. plz hlp me here.. | peter002 | HWK | 6 | 06-15-2009 15:39 |
flash for ztc ZT6698 | malacatonche | SpiderMan | 1 | 01-17-2009 10:23 |
need firmware for ztc zt6698 | peter002 | Infinity-Box | 2 | 04-25-2008 15:58 |
