need flash file e88 "S128AM01_PCB01_GPRS_MT6225_S00.S128A_NHX_E13L _TSH _V01_0327" i need e88 flsh file and eeprom.mobile is dead and also new firmware plz give me this files if any user have. COM20 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4703:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F0000100700965 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 24.10.2010): S128AM01_PCB01_GPRS_MT6225_S00.S128A_NHX_E13L_TSH_ V01_0327.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: S128AM01_PCB01_GPRS_MT6225_S00.S128A_NHX_E13L_TSH_ V01_0327.BIN project-id: S128A_NHX_E13L_TSH_V01_0327, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: S128AM01_PCB01_GPRS_MT6225_S00.S128A_NHX_E13L_TSH_ V01_0327__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\S128AM01_PCB01_GP RS_MT6225_S00.S128A_NHX_E13L_TSH_V01_0327__ffs_201 01215-194631.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 6 min 14 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
hello! try similar flash files available on support: flashfiles/ChineseMiracle/_MT6225/S128AM01_PCB01_GPRS_MT6225_S00.S128A_E13L_A88_S18_ V04_0326_16m_En_Ru_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_P t_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6225/S128AM01_PCB01_GPRS_MT6225_S00.S128A_E13L_A88_S18_ V04_0326__E88_16m_En_Ru_Fr_Es_It_Ml_Id_Th_Vn_Tr_Fa rsi_Pt_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6225/S128AM01_PCB01_GPRS_MT6225_S00.S128A_E13L_A88_S18_ V04_0326__XE88_16m_En_Ru_Fr_Es_It_Ml_Id_Th_Vn_Tr_F arsi_Pt_Ar.B0M.bin |
