05-30-2009, 17:47 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | need flash file s91 it has mt6226ba chip. on board = S91-QHMB0004B-PCB ON STRIP= S91-FPC ON LCD= TFT 8K0023FBC-A1 |
06-01-2009, 00:00 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! you must open with notepad operation.log file which is located in Chinese Miracle folder. scrool it from up from end and find First operation with this phone. there you will see Original software version. post it here, we will advice flash file which will restore your phone |
06-01-2009, 15:27 | #3 (permalink) |
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | I think this you ask for ==== log: [5/23/2009 12:51:51 PM] ==== COM12 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:EF0D:6D2C status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5F352FC5.[A8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01 M0517.BIN_986E0B6B].rpl identification#1 detection finished device-id: 5F352FC5 identification#1 protocol ver: 04 ver. sw 1: A8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01 M0517.BIN ver. sw 2: S91B_YY01_01_06.48.1.1T01M0517, 94F49167 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: A8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01 M0517__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\A8_PCB01_GPRS_MT6 226_S01.S91B_YY01_01_06_48_1_1T01M0517__ffs_200905 23-125750.B0E.bin flash: EC257E25082501:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01M 0517__system_log_5F352FC5_986E0B6B_20090523-125810.B0X.bin Finished, time used: 375 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! please help me as soon as possible, thanx for reply. |
06-01-2009, 21:39 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! try this flash file: flashfiles/ChineseMiracle/_MT6226/CM_Cect-V400_N80__A8_PCB01_GPRS_MT6226_S01.S91_YY01_01_06_ 48_1_2T03M0212_16m_En_Cn.B0M.bin unfortunately, we dont have exactly same flash file |
06-04-2009, 15:20 | #5 (permalink) |
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | LCD ok but sim problem Thank you for this file. Now LCD ok but i have another problem. when i insert sim in set and power on it, set start and off , without sim the set is start ok and open menu, everything ok, but when i use sim set starts, show his welcome screen and then off. please help me in this regard as soon as possible. |
06-14-2009, 14:32 | #8 (permalink) |
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | lcd ok but sim is not working ok without sim phone is ok, but when i insert sim phone first off, then i start again, sometime phone is running with sim but many time phone shut down. i flash the phone with safe mode and also complete flash, but problem is same. with sim phone starts and them off. please help me in this regard. |
06-14-2009, 18:36 | #9 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
Did you tried to make 112/emergence call without sim card ? What is the result ? | |
01-30-2011, 07:37 | #11 (permalink) |
Registered User Join Date: Jan 2008 Location: India
Member: 690799 Status: Offline Thanks Meter: 157 | Here is tested flash file : Sigmatel Gild Fxd S91 flash file 100% tested. This file for Spiderman box only. Sigmatel Gild S91 Spiderman 100% tested.bin Request to Infinity team to convert & upload to support site. Thanks |
The Following User Says Thank You to nakshatra For This Useful Post: |
NKTEL A200 flash file in Spider man box need flash file? | >>.123.<< | SpiderMan | 15 | 11-12-2010 16:12 |
E66 nokia need flash file no flash file in support | lilong_lee | Infinity-Box | 11 | 02-07-2010 01:51 |
!!!!! Needed, flash file for 8120 02 sfi file !!! | stemo | FuriousGold | 2 | 03-11-2009 20:08 |
L7i need flash file and boot file | aukonline | Smart-Clip | 3 | 03-10-2009 11:15 |
i need flash file and database file for t190 v 1.71 becuase | nanana | Motorola ODM | 0 | 08-17-2002 11:37 |
