Old 10-06-2008, 10:37   #1 (permalink)
KARIM GSM-ZONE's Avatar
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
Arrow Doro handleeasy 328gsm
Hi i have phone doro handleeasy 328gsm
made in sweden
www.doro.com
its that phone supported please
br
karim
Old 10-06-2008, 12:59   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is phone CPU chip name ?
Old 10-06-2008, 17:15   #3 (permalink)
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
i hope this can hellp u infinity-team
br
karim
Old 10-06-2008, 17:45   #4 (permalink)
.:Mahmoud El-masy:.'s Avatar
Member: 459407
Sonork: 100.110689
Thanks Meter: 164
what is the problem with fone ?
Old 10-06-2008, 18:00   #5 (permalink)
Member: 130995
Hello,
This phone can be supported fast.
As I can see from your picture pin-1 is GND, pin 8 is Charge.
You need to find Rx/Tx pins and you will be able to serve this phone with ChineseMiracle.
btw, how to count pins ? is your connector photo was made with keyboard up or down ?
Also, if you will be able to fid pinout and read flash, pls send flash backup to [email protected]
Old 10-07-2008, 20:37   #6 (permalink)
Member: 130995
Hello,
Any luck with pinout detection ?
Old 10-10-2008, 16:05   #7 (permalink)
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
i still have the phone but i cant found the pinout.
br
karim
Old 10-10-2008, 16:18   #8 (permalink)
Member: 130995
Hello,
Do you have Infinity-Box PinFinder ?
If you have it you can detect pinout in automatic mode.
Old 10-11-2008, 11:46   #9 (permalink)
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
Originally Posted by InfinitySupport View Post
Hello,
thx infinityteam .i get the box in few days and i will post the pinout soon
thx again
br
karim
Old 10-16-2008, 12:25   #10 (permalink)
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
hi i have infinity auto pin finder and i need hellp to found pinout
thx
karim
Old 10-16-2008, 12:36   #11 (permalink)
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
founf it
software version: 1.14
cable type: 1x8 (L8A)
platform: MT: MT6205, MT6217-MT6228, MT6230
searching adapter at COM2...
adapter found, version: 2000
pins: 8, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6223
result: Rx:2 Tx:4
time required: 5 sec
Power On !
i will try to read flash and send it
br
karim
The Following User Says Thank You to KARIM GSM-ZONE For This Useful Post:
Old 10-16-2008, 15:06   #12 (permalink)
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
thx to infinityteam for the hellp
ok phone unlocked and work perfect
but it s give me erreur after unlock, im sure phone locked before.
flash been sent to infinity support
COM2 [VCP0] selected
module v2.64
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "sp-unlock"
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
Initializing[6223:8A04]...
CPU: MT6223
high speed boot enabled
chip: 0011:66FC:000C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25032501:2AEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: CKT23_NEP324_07A_PCB01_GSM_MT6223_S00.EASYUSE3_DOR O328_DORO_L1EN_201_080529_IDW_SS53.BIN
ver. sw2: EASYUSE3_DORO328_DORO_L1EN_201_080529_IDW_SS53, 00000000
ffs offset/size: 00300000/00100000
detecting security area (code #2)...
security area (code #2) is absent
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00300000
checking area[00000000]: 00000000-003FFFFF...
eeprom/ffs found near: 003A0000
Detected eeprom/ffs address is non-standard: 003A0000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[003A0000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00060000
ffs chip: 00
eeprom/ffs area: 00000000:003A0000-003FFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[CKT23_NEP324_07A_PCB01_GSM_MT6223_S00.EASYUSE3_DOR O328_DORO_L1EN_201_080529_IDW_SS53.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT23_NEP324_07A_PCB01_GSM_MT6223_S00.EASYUSE3_DOR O328_DORO_L1EN_201_080529_IDW_SS53.BIN]_20081016-064639.B0E.bin
Backup required data Done
Patch required data...
detection procedure, wait...
error: phone is not locked or unknown eeprom
Patch required data Fail
Finished, time used: 83 sec
Remove/Install battery now !
here is the pinout
regards
karim
Old 10-16-2008, 15:12   #13 (permalink)
.:Morpheus:.'s Avatar
Member: 47774
Thanks Meter: 185
Karim very good job man keep it up
The Following User Says Thank You to .:Morpheus:. For This Useful Post:
Old 10-16-2008, 15:28   #14 (permalink)
fadhel's Avatar
Member: 39196
Thanks Meter: 126
good work karim thanks.
The Following User Says Thank You to fadhel For This Useful Post:
Old 10-16-2008, 19:20   #15 (permalink)
Member: 130995
Hello,
According to your picture I think that GND pin is at other connector side (near RX pin at your picture).
Can you double check it ?
Doro PhoneEasy 345gsm SIM LOCKED TO ORANGE FRANCE gsm-nisse Infinity-Box 35 06-14-2011 19:00
Doro PhoneEasy 345gsm not unlocked kimo59 Infinity-Box 13 11-25-2010 19:00
Doro PhoneEasy 410 US, unlock? rcll2 Various 2 07-05-2010 15:29
04 Mar 2010: Doro-338gsm, 326gsm models supported YellowBoss Infinity-Box 6 03-08-2010 02:09
08 Nov 2009: Doro, ZTE, Philips, Alcatel, Virgin models supported InfinitySupport Infinity-Box 28 12-18-2009 14:44
Page generated in 0.25493 seconds with 10 queries
