need flash file voda 125 &' 225 need flash file voda 125 & 225 urgent ihave try to support area but cant find plz infinity support help |
1 Attachment(s) Quote:
check in zte section you will found what you want.:) |
i flashed zte 125 which it was simlocke but after flash the the phone it dont power on please help me. |
why you flash your phone.. try unlock and see wot is the result and also post log here |
same problem , Hi, I have a same problem ,but when i flash my new phones vodafone 125 ,to change language packages(into romanian flashfiles),phones bateries are weak(i mean phones dont wanna stay on more then 4 hours).What can i do to my phones to stay charged more then 4 hour? |
I don\'t think that firmware upgrade can give such results. Anyway, if you think that its a result of firmware upgrade you can try to flash phone with other firmware and see results. |
i flashed the phone with flashfile which i downloaded in infinity support area,i flashed it because was simlock and not subsid code |
dear, if your phone not ask to enter unlock code; that's mean your phone is blocked. & infinity box not support phone blocked yet! |
i have problam infinity unlocked ok but phone is still locked then i try to unlock again but software says phone is already unlocked what can i do Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20080801-115152.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20080801-115156.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20080801-115203.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 35 sec |
i faced the same problem after flashing cant power on |
Hello, Did you tried to use another flash files ? |
My phone Vodafone ZTE 125 dead flashing use infinity this log : COM7 [VCP0] selected Device: ZTE-125 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20081013-182058.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.11 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20081013-182529.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20081013-183036.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 681 sec |
Hello, What was with phone before flashing ? |
