04-27-2008, 15:18 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: EingneeR
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | hi infinty team i had problem with nec com L821 log read detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CA8C:96B6 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.732477C7.[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_02_26B_YU_L7 EN_117_071022_LD-TR0_OV0_SS75_CTF_BT.BIN_00529F7E].rpl identification#1 detection finished device-id: 732477C7 identification#1 protocol ver: 04 ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_02_26B_YU_L7 EN_117_071022_LD-TR0_OV0_SS75_CTF_BT.BIN ver. sw2: LION6_02_26B_YU_L7EN_117_071022_LD-TR0_OV0_SS75_CTF_BT, 8160ADFF ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: EC257E25082501:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ..................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ..................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _732477C7_CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_02 _26B_YU_L7EN_117_071022_LD-TR0_OV0_SS75_CTF_BT.BIN_00529F7E_20080428-163923.B0X.bin Finished, time used: 204 sec Remove/Install battery now ! read general information Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: CKT26_06B_HW Software version: LION6_02_26B_YU_L7EN Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 48 sec Power off phone now ! help me team infinity please write name of flash sothat i find it in support |
04-27-2008, 20:34 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! no exactly same version on support. please make full backup (read full flash) and try following file: flashfiles/ChineseMiracle/ZTC-ZT/ZTC-ZT989_CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_02_26B _YU_L6EN_115_070920_LD-TR0_OV0_SS75_CTF_BT__16m_En_Ru_Fr_Th_Vn_Ar.B0M.bin |
04-28-2008, 21:47 | #5 (permalink) | |
Member: 201469 Status: Offline Sonork: software Thanks Meter: 50 | Quote:
thanks infinty team picture of phone 2gsm L821 i found it in : C:\Program Files\InfinityBox\pinout\ChineseMiracle 2gsm2bluetooth please give me name of flash this phone i will find it in support | |
04-28-2008, 23:04 | #6 (permalink) |
HB620T need flsh file for furious...its urgent for me .. | alternative | FuriousGold | 2 | 07-11-2009 16:18 |
Need Flsh Nec L821 (2gsm) Black | muhned | MC-Tool | 0 | 04-27-2008 19:38 |
i need flsh file for lg u300c | el-safwa | UST Pro II | 0 | 07-28-2007 18:38 |
need flsh 8330 v20a | alknadir | LG | 1 | 01-13-2006 10:00 |
I need flsh file 3510i,mcu+ppm(b) 5.25..!!! | wombladonw | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 11-27-2004 16:32 |
