02-10-2016, 03:41 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Manila Age: 47
Member: 144565 Status: Offline Thanks Meter: 71 | o+ grande unknown baseband, can't fix with cm2... i have use 2 firmware for unknown baseband... no luck... use infinitycm2... fix unknown baseband... still no luck.. logs: Start at : [2/9/2016 / 6:33:29 PM] Operation : Fix Unknown BaseBand [ v1.40 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 118 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A6681DD6791B9 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473A6681DD6791B9 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Finish at : [2/9/2016 / 6:33:59 PM] |
The Following User Says Thank You to gioguanez For This Useful Post: |
02-10-2016, 04:44 | #4 (permalink) |
Member: 144565 Status: Offline Thanks Meter: 71 | ive search for another firmware... for the third time... this one is good.. good baseband... but invalid imei... so last thing i do is repair imei... thanks for the reply... closed thread... |
