04-05-2008, 16:20 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | BSNL G200CF unlock problem COM5 [VCP0] selected Device: Digibee-BSNL-G-200CF Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now ! loading... error: can't run main loader: 8200 Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 7 sec tried holding on off button for long time still same. but after some time i tried again with other model select(coral 200). this time it did worked but phone didnt unlocked. So i think there is some loader problem |
04-14-2008, 16:07 | #3 (permalink) |
Member: 237210 Status: Offline Thanks Meter: 90 | HI INFINITY, TRIED UNLOCKING BSNL WITH NEW UPDATED MODULE, BUT STILL NO SUCCESS. Here i post both log and eprom backup COM5 [VCP0] selected Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL N W 0 A X 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Documents and Settings\bhuvan\Desktop\backup_Digibee-BSNL-G200CF_eeprom-sta_20080414-202900.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Documents and Settings\bhuvan\Desktop\backup_Digibee-BSNL-G200CF_eeprom-sec_20080414-202906.B1E.bin reading [eeprom-complete]... file saved: C:\Documents and Settings\bhuvan\Desktop\backup_Digibee-BSNL-G200CF_eeprom-complete_20080414-202916.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 59 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 Current model: Digibee-BSNL-G200CF |
04-19-2008, 17:49 | #7 (permalink) |
Junior Member Join Date: Nov 2007
Member: 637686 Status: Offline Thanks Meter: 2 | BSNL DIGIBEE NOT unlocking READ FLASH:-COM5 [VCP0] selected Device: Digibee-BSNL-G200CF Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL N W 0 A X 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-sta_20080419-213331.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-sec_20080419-213334.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-complete_20080419-213337.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_flash_20080419-213441.B1X.bin completed Finished, Remove/Install battery now ! READ EPPROM:- Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.44 S/N: 328A:010E Wait... Current model: Digibee-BSNL-G200CF Ready COM5 [VCP0] selected Device: Digibee-BSNL-G200CF Checking data, wait... Action: read eeprom Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL N W 0 A X 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-sta_20080419-213240.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-sec_20080419-213246.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-complete_20080419-213249.B1E.bin backup critical area Done Check memory... completed Finished, Remove/Install battery now ! Time used: 22 sec |
04-19-2008, 22:13 | #9 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 39
Member: 167622 Status: Offline Sonork: 100.1608761 Thanks Meter: 40 | Quote: ps: 1.43 and 1.44 give : error can't run main loader. | |
04-20-2008, 09:53 | #11 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 320 | sir i am try to unlock bsnl g200cf.. software say successful unlock.. but phone still lock its log COM4 [VCP0] selected Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL N W 0 A X 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-sta_20080419-212920.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-sec_20080419-212921.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Digibee-BSNL-G200CF_eeprom-complete_20080419-212923.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 21 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-21-2008, 13:14 | #12 (permalink) | |
check here another user have the same probleme: http://forum./showthread.php?t=528004 | |
05-22-2008, 08:00 | #14 (permalink) |
Junior Member Join Date: May 2008
Member: 777517 Status: Offline Thanks Meter: 0 | Unlocking BSNL G200CF Hi Bhuvanele, I seem to have the same problem as you are having ....Want to use a different SIM have tried the software from infinity box but nothing seems to work any idea if we need to have match the IMEI and the SIM numbers if so please give me the solution ....... |
BSNL G200CF unlock | ChandruChiyyan | Infinity-Box | 2 | 07-20-2011 09:22 |
BSNL g200cf unlock done 100% | ms_ahmed | Infinity-Box | 4 | 12-31-2008 15:56 |
>>>> BSNL-G200CF Unlocked Successfully <<<< | zeel_zeel | Infinity-Box | 1 | 12-02-2008 10:08 |
Bsnl g200cf unlocking good with et-box | sahil2000ind | ET-BoX | 3 | 10-12-2008 15:25 |
bsnl g200cf unlocking problem | shaik.shabeer | Infinity-Box | 2 | 10-07-2008 17:09 |
