11-21-2020, 09:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | need hellp for spd Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : OPM2.171019.012 Display ID : GFIVE_GPAD702_20190105 Ver. Incmt : 51111 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-11-05 Build Time : 1546692842 Product Model : GPAD702 Product Brand : GFIVE Product Name : GPAD702 Product Device : GPAD702 Product Manfct : GFIVE Product Info : sp7731e_1h10 Product Board : GPAD702 Board Platform : sp7731e SECSolution : MODERN [RS/0S/1S/2S] Operation : Flash Firmware [ v2.09 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
11-21-2020, 09:18 | #2 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
11-21-2020, 09:19 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That mean it not compatible with device in most cases. You can FORCEDLY flash it, sure, by select FW first, then select built-in loader in platform tab. But chance kill device exists. |
11-22-2020, 10:46 | #4 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | butt i tell u my windows 10 64bit and this modle r supported with cm2 spd 2 and flash file on your support site butt i have problem with this modle |
11-22-2020, 12:10 | #5 (permalink) | |
model as tested by other users that's why it is in list tested flash file was received from users who read it from good working phone thats why it exist at support problem with this model because nmaybe your model has some kind of different hw consig or something like that. do you understand this issue now ? if you need more info tell me and I will tell you more info | |
