12-29-2016, 12:44 | #1 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,695 | need help with clone S5611 samsung today i recived clone samsung with MTK 6250 cpu..it needed to change imei..but after changing imei phone stucked at welcome logo..so i decided to format the phone and it went ok but phone asked for code..luck that i have a backup flash file but every time i flash the phone it stucks at 44%..now phone is the dead... here is the logs: Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 615 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : D99E2AF6C43761C914D0B628F9934573 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : MAUI_KHAN50V11_12864_11B_PCB01_gprs_MT6250_S00.M52_561_EN_0410_V01.bin FileVersion : M52_561_EN_0410_V01 [ScatCFG] : MT6250 / M52_561_EN_0410_V01 / NOR , SF Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\MAUI_KHAN50V11_12864_11B_PCB01_gprs_MT6250_S00\ Done! Elapsed: 00:00:55 Reconnect Power/Cable! Code: Start at : [12/29/2016 / 1:11:51 PM] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 615 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : D99E2AF6C43761C914D0B628F9934573 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 Read Security data ... Verify Security data ... Set IMEI [0] : 367545285675899 Repair Repair done! Done! Elapsed: 00:00:45 Reconnect Power/Cable! Finish at : [12/29/2016 / 1:12:39 PM] Code: Start at : [12/29/2016 / 1:15:13 PM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 615 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : D99E2AF6C43761C914D0B628F9934573 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E00000-0x00FFFFFF , LEN : 0x00200000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:44 Reconnect Power/Cable! plz help me to sort this out.. btw:an error accourd appears when it stop flashing:Stream read error b.r. Last edited by bk.gsm; 12-29-2016 at 12:53. |
12-29-2016, 14:02 | #3 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Hello My Dear Friend Do You Have Scatt Firmware If You Have Just Try With This Tools FlashTool_v5.1420.00_By Palash Ahammad Fast Make A Format Than Write Firmware After Result Post Here
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
12-29-2016, 15:53 | #4 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,695 | set alive again with the help of Mr.NP but it still asking for a password which it was apeared after the first imei changing@formating.. plz CM2 help me to sort it out.. b.r. |
12-29-2016, 18:34 | #6 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,695 | hi now u will think that I'm spamming around here but really really i need your help...the phone still on my hand and i don't know what to do with it...plz guide me to solve this problem.. b.r. |
