12-12-2009, 08:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 300690 Status: Offline Thanks Meter: 12 | Need help from infinity team problem is for sim 2 imei we should use the write mode 1.. but for these models doesnt accept write mode1... so i use write mode2.but with mode2 when i writ the imei ,than it replaces to 1st imei....... i change the boot buad rate but no use what should i do. |
12-13-2009, 06:17 | #3 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | with mode 1 i an change #1 imei and when i use to cahange #2imei with mode1 software shows like image..... and i use mode2 for #2imei all the process is ok but it replaces the 1st imei |
12-13-2009, 18:18 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! just follow advice. power OFF phone, and change IMEI#2 in mode-1 just after program will start search phone- power It On. thats it, imei will be changed |
02-06-2010, 21:45 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. | |
02-07-2010, 06:34 | #12 (permalink) | |
Member: 300690 Status: Offline Thanks Meter: 12 | Quote:
Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Hardware version: MT6226, E02 Software version: M500Z_05C_HW" Software date: E553_Y15SB Barcode: 2005.04.12 imei-1: GTF0B0207360000 Finished, time used: 7 sec Remove/Install battery now ! | |
02-07-2010, 20:44 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @sartaj right now imei can not be read (I think due to communication fault). pls, read phone information several times, this helps to read imei. also, did you tried to make "format ffs" for this phone and write imei after format ? why I ask to make format ? it is because it may be that phone eeprom/ffs is damaged and it's a result of imei write problems. after format your phone will have rebuilded ffs and it may be that problem gone. |
02-08-2010, 06:40 | #14 (permalink) | |
02-08-2010, 08:46 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please give full Phone Name and Software version. i will try to find same phone here and do some tests. we are not able to solve this problem remotely |
Need help from infinity team | zeerik | Infinity-Box | 12 | 12-01-2015 07:26 |
please need help from infinity team support | HaNiNi Gsm | Infinity-Box | 4 | 12-24-2009 22:03 |
KG 195 need help from infinity team | /\/\A/\/| | Infinity-Box | 1 | 12-23-2009 16:28 |
Need help from Infinity team only | Sherif Rocket | Infinity-Box | 5 | 03-03-2009 23:20 |
Infinity Pinfinder can't Detect Need Help From Infinity | Aazib jhon | Infinity-Box | 11 | 07-14-2008 11:02 |
