Old 11-06-2015, 08:27   #1 (permalink)
Member: 442808
Thanks Meter: 195
Need help with Lenovo A1000-T
Come to me at dead condition.i read info and it show
Info read not done :( Erased phone or unsupported FlashIc?
so i decided to flash it bt it stuck.
loook at the log
Operation : Check / Read Info [ v1.35 ]
Wait for phone...
Phone found! [ 50 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575|MT6577_S00
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : M00U5
[eMMC] : FLASH_CID : 1501004B355530304D027310C4CC90C7
[eMMC] : FLASH_EXT : 00200000/00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Scatter Load Ok , BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.35 ]
======= Flash
Wait for phone...
Phone found! [ 50 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8B00
BB_CPU_SB : E201
i2c Init : 0300771F
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Setting : AFF verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000008000
Erase : 0x0000000000F28000-0x0000000061AC0000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Sent , Init passed
Tell me what to do
Old 11-06-2015, 08:43   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Try to erase flash and repeat process 2-3 times. Also try with SPFT.
If still same could be hardware.
Br.
Old 11-06-2015, 09:04   #3 (permalink)
Member: 442808
Thanks Meter: 195
thanx
it sucessfully flash with SPFT but Not Powering On
is it hardware
Old 11-06-2015, 09:41   #4 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Originally Posted by situ_saraf View Post
thanx
is it hardware
Hello,
Need to check on DA DL Checksum option in SPFT and then flash.
If you are sure your firmware is correct then could be hardware fault.
Br.
Page generated in 0.12384 seconds with 9 queries
