01-22-2018, 12:24 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 38
Member: 307225 Status: Offline Thanks Meter: 59 | (Need Help) Lenovo TB-7304i FRP Lock (Android 7.0) Please Help Us Out |
01-22-2018, 23:59 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,772 | Quote:
backup/rename existing loader - C:\InfinityBox\CM2MTK\Boot\MTK_AllInOne_DA_SP.bin and unpack/rename/copy attached one on it's place. retry operation. Be aware, that after that operation you may get "DL Image Failed" upon phone startup. In that case, Download : TB4-7304I_S000041_171018_ROW ROM, Unpack (archive pass: lenovo-forums.ru), use flasher from archive, (from folder "i-x_flash_tool"), load scatter file, select DA Agent (DA_SWSEC.bin), Go to drop-down menu "Options" -> "Option" -> "Download" -> select both options, "Usb Checksum", "Storage checksum", close window. On main window, lower part with file list, Untick all files except 'preloader' and 'cache'. Reflash phone (Download, connect powered off device to cable, wait for finish). After done, enter recovery and make "Wipe data/factory reset", then reboot. FRP is gone at that moment. take a try and post results ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 32 Users Say Thank You to Brka For This Useful Post: |
01-23-2018, 06:41 | #3 (permalink) |
Member: 307225 Status: Offline Thanks Meter: 59 | Thank You Very Much Sir. Device Done By Just Replacing Your Loader File & It's Working Fine No Error Appear. Here Is Log From CM2 For FRP Remove Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323645B8EA034285A596F2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D4203EAB8F2968485 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x7319EAF8DA209F80D37DC396330E7622 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Abid Hussain For This Useful Post: |
01-23-2018, 22:03 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Ukraine Age: 42
Member: 61559 Status: Offline Thanks Meter: 12 | help with lenovo tb-7304F if rename file but boot configuration not found Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 8167 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0xE5000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : Unknown Mode! Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
The Following User Says Thank You to podeev For This Useful Post: |
01-23-2018, 22:18 | #5 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
Also try with volume up and volume down button together connect to usb | |
The Following User Says Thank You to gile@gile For This Useful Post: |
02-06-2018, 22:35 | #7 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | NO SUCCESS LOGS Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
04-21-2018, 14:40 | #13 (permalink) | ||
Insane Poster Join Date: Aug 2011 Location: United States
Member: 1629444 Status: Offline Thanks Meter: 47 | Quote:
Thanks Alex, worked for me Quote:
04-21-2018, 20:39 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | That backup is useless. Device use signed factory firmwares, and only original, factory signed firmwares can be used to flash. btw. this is InfinityBox support section, not some crap copy/paste china tools, which you posted log from. b.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
05-05-2018, 14:09 | #15 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | THANKS BRKA Detected : MediaTek PreLoader USB VCOM Port (COM34) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 2. ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+8192Mb) SAMSUNG 0x464536324d42 EMMC FW VERSION: 03:00:00:00:00:00:00:00 EMMC CID: 15010046453632 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
